Author Topic: bleeding oil pump nozzle lines  (Read 11474 times)
heiner921
« on: November 21, 2014, 08:54:27 AM »
So i replaced the 2 lines going from the oil pump to the engine as well as the inlet line from the oil tank... I bled the inlet line to get air out to the bleeder.  I am trying to bleed the 2 little lines that go to each cylinder.. my manual says with sled running at idle to old the oil pump lever wide open.. I did that and got no results... do I need to crack the fittings for the lines at the cylinders?
Re: bleeding oil pump nozzle lines
« Reply #1 on: November 21, 2014, 02:43:17 PM »
 You could try cracking them. I have always had good results holding the pump lever wide open.  Any air in the intake line to the pump can cause issues
« Last Edit: November 21, 2014, 04:36:01 PM by Lloyd (ljm) »
« Reply #2 on: November 21, 2014, 04:14:41 PM »
You will need to hold the lever open for at least 30 sec.    Tory
heiner921
« Reply #3 on: November 25, 2014, 04:07:21 PM »
I have tried 3 pumps now. Still no luck. 2 pumps came off of running sleds..  I'm stumped
« Reply #4 on: November 25, 2014, 04:23:18 PM »
Are you sure the pump is turning?  Maybe the nozzles are plugged?  Bad banjos?
heiner921
« Reply #5 on: November 25, 2014, 04:29:00 PM »
Idk why the pump wouldn't be turning?... before I even installed then I put a drill on the shaft and spun it while hooked up to the fuel inlet to make sure it would work.... getting tired of taking the motor in and out.  On the 5th time now
heiner921
« Reply #6 on: November 25, 2014, 04:36:04 PM »
Well I tried it now with one nozzle line off and it pumps out the port
heiner921
« Reply #7 on: November 26, 2014, 06:25:31 AM »
Got it fixed. Now having a carb bogging issue.
