Author Topic: 1982 Kawi Intruder parts help  (Read 12416 times)
mrcsnow
« on: December 14, 2014, 12:42:09 PM »
1982 Kawasaki Intruder parts needed
looking for NOS or nice used
-airbox
-carburetors 2-34mm
-throttle cables
-windshield
-seat
-cdi box with plug wires
mrcsnow@yahoo.com
(815)762-6868
Thanks -Matt
Re: 1982 Kawi Intruder parts help
« Reply #1 on: December 15, 2014, 06:45:38 PM »
Matt, we have one low black windscreen left.
On those carbs, did 82 use 34mm?  I had thought that all of the Intruders used 32mm powerjet carbs.
mrcsnow
« Reply #2 on: December 16, 2014, 11:33:53 AM »
Yes my bad they have 32mm pjs.  Do you know how many 1982 Kawasaki Intruders were made?
I found a windshield
SPI throttle cables are no longer available.
I'm also looking for a cdi box with plug wires
thanks -Matt
« Reply #3 on: December 16, 2014, 01:10:59 PM »
Someone here on the site should have the statistics with the number of sleds produced each model year.  Have you tried Dennis Kirk for the throttle cable?  While it may not be perfectly identical, the Invader cable should be able to be made to work.
« Reply #4 on: December 17, 2014, 08:08:25 AM »
all intruders use similar carbs, just jetting changes.
foxspoiler
« Reply #5 on: December 17, 2014, 09:08:11 AM »
1982 Models
Intruder
Color Crimson Red
Model no: ST440-A4 Engine: TA440C
Frame serial number sst440a4 -012600---014601
Engine serial number TA440C-012603----015629
2001 total produced
mrcsnow
« Reply #6 on: January 03, 2015, 06:39:22 PM »
I was able to find everything except a coil pack with plug wires for a 1982 Intruder.
Does anyone have one or know someone who does have a coil pack with wires?
Thanks -Matt
« Reply #7 on: January 03, 2015, 08:40:49 PM »
I have a good used coil and wires off from an Invader, but I'm not sure if it'll fit?  I'm sure the coil is the same, but the wires might be different?
« Reply #8 on: January 05, 2015, 08:12:02 AM »
82 intruder used the box/coil 1 piece unit....
