Author Topic: Tricks to connect pickup line inside tank  (Read 11774 times)
JDmatt
« on: January 15, 2015, 06:22:56 AM »
Do you guys have any tricks to connect the pickup line inside the tank of an Invader without removing the tank, fitting, etc?
Matt
Re: Tricks to connect pickup line inside tank
« Reply #1 on: January 15, 2015, 07:10:46 AM »
I use a rod inside the gas line to support the line while it gets lined up and pushed on.
« Reply #2 on: January 15, 2015, 09:23:36 AM »
Ditto.  Coat hanger wire inside of hose to line up the fitting.  I can then push the hose on with another, longer piece of hose.
« Reply #3 on: January 15, 2015, 04:49:23 PM »
i tape the fuel line to a long exten,leave an inch sticking out, a little heat, slide it on the fitting, a good spray of carb cleaner on the tape, a minute later pull the rod and tape out
« Reply #4 on: January 15, 2015, 05:39:48 PM »
 I have a really long pair of needle nose pliers that I can hold the new line and push it on through the fill neck
« Reply #5 on: January 16, 2015, 08:07:12 AM »
thats a long tool..... ::)
ltdman
« Reply #6 on: January 16, 2015, 10:27:00 AM »
Lloyd has the plan! I use the same technique. I have a real long pair of needle nose pliers that have the 90 degree jaw, they work better, because you can see the fitting better when connecting the hose.
Maybe there's a better method, but it works for me. Hope our advice helps you, JDmatt. Best of Luck!
