Author Topic: How do you get your sliders off?  (Read 31567 times)
Intrigued_440
« on: November 27, 2012, 08:27:25 AM »
Just curious to see how you guys get your sliders off the rails. Is there any tricks to doing it
My Sled's:
1980 Kawasaki Invader 340
Re: How do you get your sliders off?
« Reply #1 on: November 27, 2012, 11:05:07 AM »
Remove the screw  at the front and use a hamer and chissel to drive it out the lined up window at the rear.  They can be a little stubborn sometimes.
Intrigued_440
« Reply #2 on: November 27, 2012, 12:06:28 PM »
I already removed the screw upfront. But boy is it hard to get the slider off, i used a flathead screw driver and hit it and wouldn't budge.
My Sled's:
« Reply #3 on: November 27, 2012, 02:25:46 PM »
I have used a air hammer on the real stubborn ones
Intrigued_440
« Reply #4 on: November 27, 2012, 02:42:02 PM »
If i only had an air compressor! :(
My Sled's:
79 invaders
« Reply #5 on: November 27, 2012, 03:17:44 PM »
a slide hammer works well and if not that vice grips and hammer should do ,never had to change them on one of mine that were on a running sled knock on wood :)
78 invader
2-79 invaders
80-invader
80-intruder
81 ltd
« Reply #6 on: November 27, 2012, 03:29:20 PM »
I also have beaten them out with a rubber mallet
ChaChi
« Reply #7 on: November 27, 2012, 05:08:10 PM »
Just remember heat is ur friend! Anyway you can warm those up it's bound to make them come off and go on easier!
Invader440
    • Curt's Snowmobiling Page
« Reply #8 on: November 27, 2012, 06:00:50 PM »
Soak it down good with WD40 and use the hammer and chisel.
Intrigued_440
« Reply #9 on: November 28, 2012, 01:33:13 PM »
I got the sliders off now. I cut them in pieces and spread them apart, and hit them with a block off wood.
My Sled's:
Mister Twister
« Reply #10 on: November 30, 2012, 04:30:27 PM »
I always pull the rear skid when I need to do them. Usually some more maintenance that needs to be done under there anyway, and a good inspection of the arms for cracks too.
