Author Topic: Wanted. Voltage regulator/rectifier for 1980 Intruder.  (Read 20570 times)
Gilson435
« on: March 01, 2015, 08:29:00 PM »
Hey guys, anyone have a NOS or a for sure good used voltage regulator for a 1980 Intruder?
69 Panther 372 JLO
73 Gilson 435
80 Kawasaki Intruder 440
2002 Polaris XCSP 800
Re: Wanted. Voltage regulator/rectifier for 1980 Intruder.
« Reply #1 on: March 01, 2015, 08:40:08 PM »
Without electric start they can be purchased new.  With electric start they are a little more difficult to come by.
Gilson435
« Reply #2 on: March 01, 2015, 09:42:17 PM »
Yup...looking for an electric start one.
« Last Edit: March 02, 2015, 08:24:52 AM by gilson435 »
69 Panther 372 JLO
73 Gilson 435
Gilson435
« Reply #4 on: March 03, 2015, 08:51:39 AM »
Not sure if this would work....maybe?
http://www.parkeryamaha.com/universal12vrectifierregulatorsnowmobile.aspx
Hey would ya look at that 8) I think that would work!! Thanks rminier 8)
69 Panther 372 JLO
73 Gilson 435
Gilson435
« Reply #5 on: March 03, 2015, 09:13:58 AM »
Just ordered it :) Thanks again!!
69 Panther 372 JLO
73 Gilson 435
« Reply #6 on: March 03, 2015, 03:07:59 PM »
Yep, that looks good. I will mention a couple things that you have probably already thought of. If so, my apologies.
  You mentioned over on Vintagesleds you didn't want to hack up your sleds wiring harness....understandable. You could take your original, bad rectifier/regulator and cut the wires back from it's plug, and splice the new one into those wires. That way it would plug into the stock plug coming from the motor.
  I took a peek at the '80 Intruder wiring diagram. It shows an in-line fuse in the wire going to the battery positive terminal. I think that would be a good thing to keep in place, if this replacement your getting doesn't have the fuse. It should work great without the fuse.....until...
  If the rectifier part ever failed in the future, the fuse would blow when the rectifier fails to convert AC voltage to DC voltage.
  If the regulator portion ever failed in the future, the fuse would blow when you started getting 18-20 Volts from the lighting coil, rather than the proper "regulated" 13 or 13.5 Volts.
  It's not the end of the world if the regulator fails and you blow a light bulb or two, but it would suck to send too high voltage to the expensive battery and boil all of the acid out of it.
  Let us know if this replacement works...might be helpful to know for those that have electric start Kawis. 8)....Rick
Gilson435
« Reply #7 on: March 03, 2015, 03:18:05 PM »
Thanks Rick! Yes that was my plan to cut the plug off my old regulator/rectifier and solder it on to the new one. That way I will still have my fuse holder going to the battery and all of my original wiring :) I'll let you know how it works when I get it done.
69 Panther 372 JLO
73 Gilson 435
« Reply #8 on: March 03, 2015, 06:22:23 PM »
That looks very promising.  Please let us know how it works.
Gilson435
« Reply #10 on: July 08, 2015, 02:40:58 PM »
Hey guys! I haven't forgotten about you, just been busy with summer projects. Still haven't installed the voltage regulator yet. But I promise I will and I will let you all know how it works!
69 Panther 372 JLO
73 Gilson 435
Gilson435
« Reply #11 on: January 04, 2016, 08:15:08 AM »
Well I finally got around to installing the new reg./ rectifier and it works perfectly!! I cut the connector off of my original reg./ rectifier and soldered and heat shrunk it to the new one. So anyone looking for a replacement for electric start models this is an exact fit!! Thanks for the help!! 8)
« Last Edit: January 04, 2016, 11:24:49 AM by Gilson435 »
69 Panther 372 JLO
73 Gilson 435
« Reply #12 on: January 04, 2016, 10:58:07 AM »
 Cool! Glad that worked... 8)
« Reply #13 on: January 04, 2016, 06:22:29 PM »
Excellent information.  Thank you.
ltdman
« Reply #14 on: February 01, 2016, 10:36:44 AM »
Just changed mine a few days ago on my Invader 4/6. Part # 21066-3501 or after market Kimpex #01-154-33.
