Author Topic: invader 340 vs 440 heads  (Read 51652 times)
jasoniowa
« on: October 15, 2012, 05:35:08 PM »
are the 340 heads the same as the 440 heads?
Invader440
    • Curt's Snowmobiling Page
Re: invader 340 vs 440 heads
« Reply #1 on: October 15, 2012, 05:59:04 PM »
No, look the same, bolt on the same, but your bore is a different size.
« Last Edit: October 15, 2012, 06:00:42 PM by Invader440 »
jasoniowa
« Reply #2 on: October 15, 2012, 06:02:24 PM »
Will it hurt it if i were to put them on? the motor only has 122 PSI of compersion.
« Reply #3 on: October 17, 2012, 04:53:46 AM »
 They might not seal very well.
 If you try, Let us know how well it works
JDmatt
« Reply #4 on: October 17, 2012, 07:35:47 AM »
122 isn't that bad as long as both sides are close to that, bare minimum to run is usually 90.
Matt
jasoniowa
« Reply #5 on: October 17, 2012, 05:09:25 PM »
Well the problem I have is that the sled is super fast pulls the skis off the ground for about 10 mins then bogs and wont move carbs have been gone threw new crank seals pistons and rings. its not a true inavder 440 motor i have john deere liqufire heads on it so thats my last option was to put invader heads on it any suggestions will be great.
Jason
JDmatt
« Reply #6 on: October 17, 2012, 07:40:46 PM »
Does it start up OK again when it cools off?  Sounds more like an spark problem.  Stators, coils, or CDI can fail once they get heat-soaked, then work again when they cool off.
Matt
jasoniowa
« Reply #7 on: October 17, 2012, 08:21:09 PM »
It starts up just fine runs good when its cold but its super boggy and then gets so boggy it dont move this sled has the old ignition system on it like my 82 liqufire has the newer could that be the problem? I know there was issues with the older ones.. this ignition system was on a intruder 440 that i have on my invader 440 now.
« Reply #8 on: October 18, 2012, 05:12:23 AM »
 I would be really surprised if heads would make any difference.
 I know this sounds obvious but have you changed sparkplugs?
 I have a 440 Drifter that was doing the same thing. I spend hours trying to figure it out.
 Had good spark on both plugs cold, sled ran really good till it warmed up, then would hardly move itself. spark tester showed spark on both sides, Finnally I changed the plugs and problem went away.
 If someone had told me a plug would would work cold and not work hot I would have had a hard time believing that. But now I check that on all my sleds first.
Good Luck
jasoniowa
« Reply #9 on: October 18, 2012, 07:34:09 AM »
I've tryed several differnt plugs all the same, also it heast up with in five minutes of running thermostat opens and works fine just heats up really fast.
« Reply #10 on: October 18, 2012, 11:35:35 AM »
I think if you put 340 heads on the 440 the piston would hit the head around the skirt.
jasoniowa
« Reply #11 on: October 18, 2012, 01:38:57 PM »
Yeah im gonna stick with the liqufire heads on it im just gonna pull the motor and go threw it again i think my seals are no good again.
« Reply #12 on: October 18, 2012, 07:25:45 PM »
Jason
I had a ski-doo that did this exact same thing.  It ended up being a bad CDI box.  I don't think the Deere heads would cause this issue.
JDmatt
« Reply #13 on: October 18, 2012, 08:01:42 PM »
Agreed, it sounds like an ignition issue.
Matt
jasoniowa
« Reply #14 on: October 19, 2012, 09:14:19 AM »
Thats what im starting to think too. If any one has a cheap igniton system let me know thanks
