Author Topic: The long wait  (Read 42767 times)
79Intruder
  • Stripping down 79 Intruder
The long wait
« on: December 06, 2012, 05:18:09 PM »
Well here is my story. I got my Kawasaki Intruder 440 about six years ago. I got it running after I replaced the gaskets, But just when I got all excited to hear it run The recoil broke. It stopped the engine really quick.  So from then on I decided that I was going to rebuild it. Here i am 5 years later, and still trying to get it done. Keep running into that out of money thing. I am hoping to have it done in two years. That will be my goal.
JDmatt
Re: The long wait
« Reply #1 on: December 06, 2012, 07:46:46 PM »
I hear ya.  I have a JD 600 that I started restoring like 8 years ago, and just keep putting it on the back-burner.  Funny thing is it's almost done, but on the back-burner at the moment  8)
Matt
Re: The long wait
« Reply #2 on: December 06, 2012, 08:16:58 PM »
Welcome to the site!! we can walk you thru it if needed.
79Intruder
Re: The long wait
« Reply #3 on: December 07, 2012, 07:11:43 AM »
Well it's going to be fun to do. I just wish I did not have to save the engine for the last thing. The rest of the sled is going along nice. I know that I need a new crankshaft. I think it has water damage. Now It will not turn at all, But I did get to hear her run even if it was for a few minutes. I will try and get up some pics after Christmas.
Re: The long wait
« Reply #4 on: December 07, 2012, 10:21:24 AM »
Where are you located? maybe someone can help out with parts...
79Intruder
Re: The long wait
« Reply #5 on: December 07, 2012, 01:55:46 PM »
I live in N.H. , But I have no money right now...  I have parts to trade they are for Yamaha.
Re: The long wait
« Reply #6 on: December 07, 2012, 03:43:25 PM »
What makes you think it has water damage?
 Have you taken the recoil off?
Re: The long wait
« Reply #7 on: December 07, 2012, 07:00:36 PM »
I have revived motors using Marvel Mystery Oil in the cylinders when they won't turn over (used on a few motorcycles ) mostly from sitting without running for a few years. add the oil, let it sit for a day, then work the crankshaft back and forth until it frees up. This won't work on a broken ring or other catastrophic failure.
79Intruder
Re: The long wait
« Reply #8 on: December 08, 2012, 11:18:05 AM »
Yes I took off the recoil. I have the engine striped down as far as I can get it. The arms have rust on them, so does the crank. The person that I bought it off from said it had water in it before. But that he took care of it. What I would love to do is to spit the case and see more of the crank. I do not have the puller to take the hub off. I also can't find the same engine anywhere. Do you know where I could get a puller or to rent one? Thanks.
ChaChi
Re: The long wait
« Reply #9 on: December 08, 2012, 11:28:20 AM »
If you don't want to take it apart, don't have the time and tools, I would pickle it...
fill it will diesel fuel and maybe a bit of 2 stroke oil...
Fill the crank case and also little down the plug holes, and after a day of sitting (don't turn over with plugs in) with the plugs out gently tap down on the highest  piston with a dowel...
Once she frees up pour another ounce of oil 2 or 4 stroke in each cylinder and rotate it several times, then put a line on the crank case breather into a bucket and purge the engine of the pickling juice by rotating it... A drill could be used on the clutch, if you rotate it a ton you may want to use a bit more oil in the plug holes... once it no longer has any diesel left, re introduce some 2 stroke mix gas in the case and purge then repeat 2 or 3 times to get all the diesel out...
Then start...
I have done this to motors that ran for many hours after, I also have done this to motors that didn't run ten minutes... It's all in what damage has been done...
It is by far a better idea to dissasemble the motor and inspect everything...
Remember you can go further on snow using a snowmobile in 30 minutes then you can walk in a day!
ChaChi
Re: The long wait
« Reply #10 on: December 08, 2012, 11:29:22 AM »
ATF and gas mix also works but I have never used it, it maybe better then diesel because you wouldn't have to make sure it's all out!
ChaChi
Re: The long wait
« Reply #11 on: December 08, 2012, 11:37:19 AM »
A little rust on the crank and connecting rods is no huge deal just take it off with a non agressive wire wheel and make sure no debris gets into the bearings, to take it off the crank you will need to get a flywheel puller... They can be very stubborn, and I recommed a tiny bit fo anti sieze on it when reassembling... Some places do loan out tools here in canada, canadian tire and some parts stores not sure about states side tho...
Rust in the cylinders or bearings is a big deal and they will need to be replaced or in the case of cylinders re plated or if it's very light maybe maybe get away with a light hone....
Re: The long wait
« Reply #12 on: December 09, 2012, 12:39:29 AM »
The clutch puller is not too expensive, and worth the investment. Denniskirk.com has them as will most parts places that handle snowmobile parts.
The flywheel takes a puller made for flywheels, Vibration dampeners, or steering wheels. A heavy duty one is a good idea, and make sure you use grade 8 bolts that thread into the flywheel.
Flywheels are extremely tough to get off sometimes.
79Intruder
Re: The long wait
« Reply #13 on: December 09, 2012, 08:18:48 AM »
Thanks. I will try a puller that I can rent first. I bought one last year. It was a universal. Right right now I am getting the steering assembly off. I am having trouble getting one of the bolts off. The one that near the bottom u arm. I don't seem to have the right size wrench. Got one out with no problem. I have been socking it in wd40. I hope this will help. I don't have heat to put to it, And with the rubber being right there too. I can't cut it off ether can't get to the other side of it. Well if that is my biggest problem with it i'll be happy.
Re: The long wait
« Reply #14 on: December 09, 2012, 08:26:32 AM »
 I'm curious  Why would you need to get all the diesel fuel out?
