Author Topic: Bulk heads  (Read 8385 times)
Bulk heads
« on: December 26, 2015, 02:55:11 PM »
Is there much difference on the bulk heads from Invader to Interceptor minus bracket tree ?
Re: Bulk heads
« Reply #1 on: December 26, 2015, 02:56:38 PM »
Width spindle to spindle & where the engine sits in the chassis
Joel
Re: Bulk heads
« Reply #2 on: December 26, 2015, 03:07:16 PM »
I will go and do some measuring. Going from memory spindle to spindle is 3" wider on Interceptor but I think inner bulk head is the same.
Re: Bulk heads
« Reply #3 on: December 26, 2015, 06:01:18 PM »
Depending upon the year, the engine mounts will be different.  The Interceptor should be the same as the 81/82 LTD.  The mounts for the other year Invaders will be slightly different.  We went through the process of converting a 81 LTD to accept a 1979 engine.  While not particularly difficult, i don't plan to do that again.
