Author Topic: 1980 340 drifter.  (Read 13330 times)
Viking
1980 340 drifter.
« on: January 17, 2016, 10:00:49 AM »
This is our new snowmobile. 12 year old son and myself went in on it, got the original helmet with mask and owners manual. 335$
We went all through motor n fuel system. Runs great but clutch spring seems like its too weak, early engagement. What clutch did they come with and what's the best spring to use for strong pull off the line?
Viking
Re: 1980 340 drifter.
« Reply #1 on: January 17, 2016, 10:13:07 AM »
Helmet n mask
Gilson435
« Reply #2 on: January 17, 2016, 10:19:42 AM »
Nice buy! I dig the Helmet & mask!!
69 Panther 372 JLO
73 Gilson 435
80 Kawasaki Intruder 440
2002 Polaris XCSP 800
Viking
« Reply #3 on: January 17, 2016, 12:15:14 PM »
Thanks, what's the clutch and what spring do I need? riding today its 15 below zero 8). little drifter is only 370 lbs. runs out to 60 on speedo.. handle incredible.. what a fun sled!!
« Reply #4 on: January 17, 2016, 12:48:03 PM »
 Nice pictures! The '79 and '80 Drifters used the Arctic Cat Hex clutch. The '81 Drifters used the Kawasaki clutch, like the Intruders and Invaders used....with different springs and ramps, etc.
 Nothing wrong with the Hex clutches...they tended to wear the center bushing out...just like the SkiDoo square shaft clutches did.
 The shop manual says your '80 Drifter should engage at 3500 RPM, and hold at 63-6500 when shifting.
 If your clutch is original, it should have a yellow spring.....an Arctic Cat spring....not a Kawasaki clutch spring.
 A green spring was offered as an option, which was slightly stiffer, and would raise the engagement slightly.
 Your spring might have lost a little bit of its "spring" over the years if it is engaging much below 3500.
 Those Hex springs are still available from lots of places, if you decide to replace yours.
 It sounds like your Drifter is running well if your seeing near 60 mph! 8)
« Last Edit: January 17, 2016, 12:57:51 PM by rminier »
Viking
« Reply #5 on: January 17, 2016, 02:58:36 PM »
yes It runs great. I replaced all gaskets and seals, new fuel pump kit, carb kit. totally disassembled n clean each part. motor looked like new when I had it apart. I like riding it as much or more than Polaris xlt, cause it so light n nibble..
Great insight thank you..
Has yellow spring now. I think I want green one
« Last Edit: January 17, 2016, 03:01:47 PM by Viking »
dr1979-340
« Reply #6 on: January 27, 2016, 03:17:41 PM »
Is that the one that was for sale in New Ulm, MN?
Two 1979 340 Drifters
1979 440 Drifter
1980 440 Drifter
Viking
« Reply #7 on: February 01, 2016, 09:08:33 PM »
NO got by Mankato mn.
dr1979-340
« Reply #8 on: February 02, 2016, 04:40:15 PM »
I think it's the same one.  I recognize the helmet and face-mask with the snowmobile from the Craigslist add.  I talked to the guy about it.  It sure looks familiar.  Glad it went to someone that appreciated Kawasaki snowmobiles!!  I have 4 Drifters now.....two '79 340's I restored last year and am currently working on a '79 440.  I have a '80 440 for a future project some day.
1979 440 Drifter
1980 440 Drifter
Viking
« Reply #9 on: February 02, 2016, 06:28:40 PM »
could be. We got it from courtland, mn. needed seals, gaskets, clutch work ect. Its got new brakes, warebars, belt, clutch spring now. Rides like new, but could use stiffer suspension spring. I want jetting chart for it. got 200 main and 30 pilots now. Its been warm, 30 to 40degrees so I was thinking 190 n 25.. just kinda dog when its warmer out.
