Author Topic: kawasaki invader rod bearings  (Read 8779 times)
Tanner
« on: January 29, 2016, 01:21:36 PM »
Does anybody know where i can get the bottom bearings for the connecting rods for my kawasaki invader 340? I see a lot of wrist pin bearings for the top but nothing for the bottom.
Re: kawasaki invader rod bearings
« Reply #1 on: January 29, 2016, 01:28:11 PM »
Being that the crank must be pressed apart to replace the rod bearing and Invader cranks are relatively plentiful, most guys opt to swap in a good used crank rather than replacing a rod or inner crank bearing.
I am unsure about the Invader cranks, but last time I had crank work done on an Interceptor/LTD crank the rod bearings were not available.  I would suggest contacting Jerome at Crankshaft Services to inquire.
« Last Edit: January 29, 2016, 01:33:12 PM by gixxer6 »
jd440
« Reply #2 on: January 30, 2016, 06:26:43 PM »
Jerome was an Endro Team Deere (factory race team) tech and race sled builder in the mid 70's, Liquidator & later Liquifire I-500 days.  The last I heard he was getting out of the crankshaft rebuilding business.  Please correct me if I am wrong.
« Last Edit: January 30, 2016, 06:32:32 PM by jd440 »
