Author Topic: Replacing Hand Grip  (Read 13601 times)
dr1979-340
Replacing Hand Grip
« on: February 11, 2016, 09:00:53 AM »
I bought a new OEM hand grip to replace one that is mangled on the end.
Does anyone have advice on this?  I was thinking about putting the new one in boiling water for a minute or so to make it soft, then sliding it on.
Two 1979 340 Drifters
1979 440 Drifter
1980 440 Drifter
DougKauer
Re: Replacing Hand Grip
« Reply #1 on: February 11, 2016, 11:13:56 AM »
I think that you can use a hair dryer to soften the rubber up, try this first.  :D
« Reply #2 on: February 11, 2016, 02:52:05 PM »
Cut the old one off first, then put the old one in boiling water or use a heat gun to test how it will react.  This way if it ruins it, you won't destroy your new grip.
Gilson435
« Reply #3 on: February 11, 2016, 02:58:27 PM »
Good idea!! I have used both methods but use the heat gun most often cause it's easier and faster. Then I use a rubber tipped air blower to blow compressed air into the end of the grip while pressing it onto the bar. Sometimes you have to hold your hand over the other end of the opposite grip. Polaris used plastic plugs in the end of the bars so that made it easy. Heat grip, add air, and it would blow up like a balloon and slip right on 8)
69 Panther 372 JLO
73 Gilson 435
80 Kawasaki Intruder 440
2002 Polaris XCSP 800
dr1979-340
« Reply #4 on: February 11, 2016, 03:55:52 PM »
Thanks guys!!  I don't have a hair dryer, because I don't have any hair to dry.  No heat gun either.  I suppose I can borrow one or the other.
1979 440 Drifter
1980 440 Drifter
Gilson435
« Reply #5 on: February 11, 2016, 07:37:27 PM »
Hot water works too! Not sure I'd use boiling water though....
69 Panther 372 JLO
73 Gilson 435
« Reply #6 on: February 11, 2016, 07:52:30 PM »
I have always put mine on at room temperature.  The old ones tend to be stuck on pretty good and it takes a little prying with a screwdriver and a shot of WD40 and an occasional smack with a rubber mallet to get them off.  After cleaning off the WD40 the new one goes on with a few taps of the rubber mallet.  Again, this is at room temperature in the garage.
« Reply #7 on: February 15, 2016, 12:34:51 AM »
Visit a chicks house and borrow her aqua net hair spray.  The fastest and easiest way to change hand grips.
I use a screw driver and wedge it in.  Then I spray some aqua net between the grip and handle bar, twist and pull off.
Putting on I spray some aqua net into the hand grip and slip on.  Let it dry a bit and presto.
FAST.
