Author Topic: Kawasaki charity build.  (Read 168722 times)
0 Members and 9 Guests are viewing this topic.
BornagianKawi
Re: Kawasaki charity build.
« Reply #60 on: July 30, 2016, 08:19:35 AM »
Here we go-
BornagianKawi
« Reply #61 on: July 30, 2016, 08:24:34 AM »
More-
« Reply #62 on: August 01, 2016, 02:37:04 PM »
Looks great!  Are there more parts that you need?
« Reply #63 on: August 01, 2016, 09:35:58 PM »
A picture of the parts.
« Reply #64 on: August 06, 2016, 09:24:17 PM »
Anyone out there tried to up grade the 2 bushings and sleeve for the suspension shock to a good rubber one like the other end of the shock??  That to me seems like a better choice.
BornagianKawi
« Reply #65 on: August 08, 2016, 07:11:05 PM »
Hey them parts are looking great. The bushing idea sounds great, don"t know why it can"t be done.
« Reply #66 on: August 08, 2016, 08:56:24 PM »
Thanks!!  I decided to try the rivet game putting it back together.  Note to self------  make sure to be sure the parts fit before you paint and try to rivet them back in place!!!!!!!!!!!!!!!!!!!
« Reply #67 on: August 11, 2016, 09:27:28 PM »
Parts look awesome those rivets are a trick if you have the wrong tooling
« Reply #68 on: August 12, 2016, 07:52:02 AM »
I made a couple little pieces to help but it but it is still a challenge.
BornagianKawi
« Reply #69 on: August 12, 2016, 04:56:27 PM »
We use to have tooling on the farm, to do sickle blades, for cutting hay. One tool was a rail road iron. Might not be good here.
« Reply #70 on: August 13, 2016, 10:40:35 AM »
I never tried the solid rivets, cool that is what you are doing.....I have a few brackets if any turn out bad.....great work
« Reply #71 on: August 13, 2016, 09:54:47 PM »
After thinking I would just put bolts in I changed my mind.  I found bulk rivets of the correct size so why not try to keep it original if I can.  It takes 4 hands to do it this way but I think it will turn out OK with a helper.  Before I finish the rivets I need to do a little welding to repair a worn spot where the front suspension spring did some damage to the rail.  I kind of stepped into a hornets nest with this one!!  LOL
« Last Edit: August 13, 2016, 09:59:25 PM by Interceptor398 »
DougKauer
« Reply #72 on: August 14, 2016, 09:50:05 AM »
I have all the NOS decals for the 1980 Invader, except the lower section ,the 340 and the words Kawasaki if you might need these. could use one extra section to make the lower section up.  Let me know if you guys could use these.   Doug
« Reply #73 on: August 15, 2016, 02:18:18 PM »
I dig your helper and the work clothes
« Reply #74 on: August 16, 2016, 06:56:04 AM »
Clamp the parts they make a tool for air chisel that shapes the dome of the rivet the backer is a solid block I have some of those tools it's really not that bad
