Author Topic: vari-ride suspension travel increase  (Read 7815 times)
Teherr
« on: April 10, 2016, 05:06:00 PM »
I was re-assembling the rear section of my 82 LTD vari-ride and I believe it would be fairly easy to increase travel by 1- 1.5"  by simply lengthening the stop strap, and using the new kimpex gas shock that is recommended to this sled.  See attached pics.  Has anyone tried this?  I plan to.  1"-1.5" is a good gain when your starting with only 4-5" stock.
There are two limited factors that prevent you from increasing more.  1.  the spring length that slides on the rear block and you can't get too close to strait on the pivoting elbow. But, I did measurements and test, I am pretty confident I get get over 1" easily.
I also have an 80 LTD vari-ride and this mod is not possible with this model because the rear section is different and the pivoting elbow cannot straiten any more than stock.
440 Invaders
440 LTD Monohead
Liquifire
80' 4/6
Intruder Ice Oval Racer
74 El Tigre T7 Free Air
80 Polaris 440 TX
250 & 340 Enticers
Re: vari-ride suspension travel increase
« Reply #1 on: April 11, 2016, 12:23:20 AM »
You could lengthen the links to gain more travel...
