Author Topic: Interceptor jetting  (Read 26090 times)
huskerfarmer
Interceptor jetting
« on: January 05, 2017, 09:14:56 PM »
I acquired an Interceptor that came from altitude? It is equipped with 36 VM mikuni carbs with the power jets. I am looking for recommendations for jetting at nearly sea level. All help will be appreciated.
Re: Interceptor jetting
« Reply #1 on: January 06, 2017, 07:38:25 AM »
Welcome to the site!!  I think that carb swap has been done a few times so someone here has the answer.  Have you tried to run it?
BornagianKawi
« Reply #2 on: January 06, 2017, 05:01:48 PM »
Go to Interceptor Gang--then look at JETTING, For 38"s but may help.
huskerfarmer
« Reply #3 on: January 06, 2017, 09:53:41 PM »
Thanks for the replys. No I have not tried to run it, as I am going thru the fuel system. I am hoping to hear from someone that has successfully used the 36's on the 550.
Joel
« Reply #4 on: January 07, 2017, 09:22:38 AM »
I would strongly recommend discarding the 36 powerjets for some 38 non powerjets. where are you in Nebraska?
« Reply #5 on: January 07, 2017, 06:07:23 PM »
There was a guy from Iowa several years ago who took stock 4/6 carbs and put them on a 550.  He claimed it ran great.
huskerfarmer
« Reply #6 on: January 08, 2017, 08:23:05 PM »
Joel; To answer your question I live south of Omaha Ne. Why?
Joel
« Reply #7 on: January 10, 2017, 06:58:03 PM »
Just curious I guess how close you were. Any pictures of your ride?
BornagianKawi
« Reply #8 on: January 16, 2017, 03:01:18 PM »
This is what I have on mine, built by Bob at Image.
  valve throttle  2.5
  needle  6DH4
  main jet #360
  needle jet #165-Q0
  pilot jet #40
 These are non-primer carbs 36"s.
 Carb marking"s  MKA
  Also with K&N filters & sno-chargers
« Last Edit: January 16, 2017, 07:23:26 PM by BornagianKawi »
huskerfarmer
« Reply #9 on: January 18, 2017, 09:41:29 PM »
Thank you for the specs, that will help!
