Author Topic: need help with invader 440 clutching  (Read 93847 times)
Kal k
« on: February 15, 2017, 08:43:46 AM »
Hi, I just bought a 79 invader and am planning on taking it to some drags. As of right now I got the motor out and going through it plus doing all the seals. Gonna start by making sure it's running good. I'm planning on putting a 102c comet clutch on it and was wondering what spring and weights a guy should get to make it engage in that 4500 - 5000 rpm rang and rev out at 7900 - 8000 rpm. I know this stuff takes lots of trial and error to get it perfect but was hopping someone could point me in the right direction. Thanks
Re: need help with invader 440 clutching
« Reply #1 on: February 15, 2017, 06:38:06 PM »
 This is the recommendation's from Comet for a Deere Liquifire. Very similar engine.
http://www.hoffcocomet.com/EpiphanyWeb/FlexPage.aspx?ID=122
Use the Liquifire  436.   B1 weights are hard to find. N weights will work.
This page has lots of info on the comet clutch.
http://www.hoffcocomet.com/EpiphanyWeb/FlexPage.aspx?ID=118
« Last Edit: February 15, 2017, 06:41:07 PM by Lloyd (ljm) »
« Reply #2 on: February 15, 2017, 08:25:15 PM »
Welcome to the site!!  I moved this to the racing thread in the hope that after some time it will be the go to place for Kawi racing info.  Good Luck!!
Kal k
« Reply #3 on: February 15, 2017, 11:53:10 PM »
Thanks for the welcoming. This sight has been a big help so far and thanks for the advice
« Reply #4 on: February 16, 2017, 06:16:11 AM »
Here is a list that includes many Kawasaki sleds
http://www.hiperf.com/acatalog/cometcalguide.pdf
« Reply #5 on: February 16, 2017, 07:24:30 AM »
I have little experience with comet clutched, but I have a good drag setup for the stock Kawasaki clutch that will get you what you are looking for.
Kal k
« Reply #6 on: February 16, 2017, 01:10:46 PM »
The sled came with a power block clutch on it so if I'm gonna switch it sounds like the 102c is the way to go if I'm spending the money. But I would still like two know what you setup is. And dos anyone know what springs work in the 102c clutches other then comet springs?
« Reply #7 on: February 16, 2017, 02:39:27 PM »
 Most of the Kawasaki's, including the Invader, use a rather unique negative offset of -0.200 inches in the drive clutch where the 30 mm taper begins to mount on the crankshaft.
 Comet makes one for these sleds...model # 208306 with that exact offset.
The vast majority of clutches are "flush mounted"....millions of sleds are that way.
That means if you get a clutch with the common flush mount, it will sit 0.200 inches closer to the engine when installed....nearly 1/4 inch!
 It will fit but I'm not sure you can move the secondary clutch in towards the center of the sled and maintain proper clutch alignment.
 Maybe someone on here has used a flush mount Comet and can comment how it worked.
I think the Polaris P-85 drive clutch springs work in the Comet, too....but I'm not positive.
« Reply #8 on: February 16, 2017, 03:05:57 PM »
 I'm sure gixxer6 could help with the stock clutching if you want to go that direction.
Here's one on Facebook...stock clutches engaging at 5600... 8)
« Reply #9 on: February 17, 2017, 11:43:15 AM »
The 1980 John Deere Liquifire came with a 102C from the factory.  As Llyod mentioned, they have almost identical engines so the stock liquifire calibration should be really close, so a good used Liquifire clutch should be a good starting point.
I might have an extra Invader/Liquifire 102C if you are in the market?
« Last Edit: February 17, 2017, 01:35:44 PM by gixxer6 »
Kal k
« Reply #10 on: February 17, 2017, 02:33:07 PM »
Ok thanks and I already picked one up. Thanks for the offer
Kal k
« Reply #11 on: February 18, 2017, 08:46:46 AM »
Gixxer6. I'm curious to know what you did with the gearing or did you just leave it the same
« Reply #12 on: February 26, 2017, 12:53:33 PM »
Stock gearing and stock secondary.  I modified a set of E ramps to Aaen spec, and used a red Kawasaki spring.  Then adjusted the ramp weights until I got the desired max RPM, being the rest of the sled is stock-ish, 8,000 RPM.  I believe for me I ended up with stock ramp bolts with 3 thick washers on each.  This gave me a wicked launch, I don't recall the exact engagement rpm, but it made my Invader scary fast.  It's an excellent drag setup, but not very trail friendly.  I played with the clutch a lot, and ended up with stock.  I do keep a clutch setup with the Aaen weights in case I ever get someone that wants to race all I have to do is pop it on.
Kal k
« Reply #13 on: February 26, 2017, 02:32:29 PM »
Ok I'll have to give it a try. I'm having problems with it having a bit of a bog right now coming out of the hole. So gotta get that figered out. I changed the main jets to 135s because I thought it was to fat. I'm wondering if that hurt it more than.  Anything
Kal k
« Reply #14 on: February 26, 2017, 03:03:10 PM »
So how many grams of weight would the e ramps be with the washers in them about?
