Author Topic: bouncing tach  (Read 14046 times)
Kal k
bouncing tach
« on: March 05, 2017, 10:06:39 AM »
I have a 79 invader and it has a bad bouncing tach and tryed a tach off a 340 invader on it and it dos the same thing. Any ideas?
sxrsist
Re: bouncing tach
« Reply #1 on: March 05, 2017, 10:27:22 AM »
i have tried a few tachs. never get smooth reading either.
Re: bouncing tach
« Reply #2 on: March 05, 2017, 10:40:22 AM »
I had an Invader with a bouncy tach, I replaced it with a NOS tach and the problem went away.  It seems like when they get worn they bounce.
Re: bouncing tach
« Reply #3 on: March 05, 2017, 01:13:52 PM »
http://kawasakitrax.com/kawiforum/index.php?topic=1657.msg10735#msg10735
I haven't tried what "sprocket" suggested on this, but I intend to. I bet it works.
I wonder if there is a cheap resistor inside the tachs that wears out after 40 years?
« Last Edit: March 05, 2017, 03:45:54 PM by rminier »
Kal k
Re: bouncing tach
« Reply #4 on: March 06, 2017, 06:47:22 AM »
Ok thanks for the help
sxrsist
Re: bouncing tach
« Reply #5 on: March 12, 2017, 10:16:02 AM »
i had a tach the never bounced on my invesder and swapped with ltd and still bounced on ltd and ltd one never bounced on invader. its in sled i think
Re: bouncing tach
« Reply #6 on: March 12, 2017, 03:18:16 PM »
The tachometer is simply a voltage meter that reads the voltage from the engine. as it runs faster, it makes more voltage. Since the voltage made is AC, there is a regulator that converts it to DC and they use that for making spark and lights. I wouldn't worry about a bouncing tach too much as it isn't even that accurate anyhow.
Re: bouncing tach
« Reply #7 on: March 13, 2017, 06:58:34 AM »
These tachs are pulse counters, not volt meters.  The faster the motor spins, the higher the frequency of the pulses.  They should be quite accurate.
Kal k
Re: bouncing tach
« Reply #8 on: March 14, 2017, 10:26:13 PM »
I ended up putting a after market tack on my invader and it fixed the problem. Thanks for the help
Re: bouncing tach
« Reply #9 on: March 15, 2017, 07:39:23 AM »
There should be plenty of used tach's out there?
