Author Topic: Carbs for Interceptor  (Read 42897 times)
« on: October 15, 2017, 11:14:49 AM »
Hi
 Has anyone used carbs from a 82 LTD on an Interceptor?  Can they be rejetted to work?  Or am I better to use Mikuni's?
Re: Carbs for Interceptor
« Reply #1 on: September 22, 2019, 11:19:47 PM »
Lloyd,
If I was going to put on mikunis ditch the VM or round slides and head straight for the flatsides.  You can pick up a set off of a 2002-2006 Polaris 600.  The thumb weight will be extremely lighter.  That Pol came with  38mm miks and you can probably pick up a set for around 100 clams.  The jetting may be close then a wideband aftermarket o2 sensor and stand alone system is in the 200 clam range.
