Author Topic: Camoplast track on 550  (Read 10727 times)
BornagianKawi
« on: November 05, 2017, 02:32:50 PM »
Going to install a Camoplast track, Durasport, #9796t on a 550, question is, on adjuster wheels on the suspension in back, could I run 3, two outside, 1 in the middle, or 4 and adjust accordingly with spacers? What"s the recommendation?
Re: Camoplast track on 550
« Reply #1 on: November 05, 2017, 06:42:06 PM »
Three would roll a little easier but 4 would be more stable but sounds like a "I do have the parts for this"  kind of job.
BornagianKawi
« Reply #2 on: November 06, 2017, 05:09:33 AM »
Oh, yes all parts are here. I did one before with 3 wheels, but only has 4 miles on it.
« Reply #3 on: November 06, 2017, 07:29:45 AM »
That track should grab pretty good!
Joel
« Reply #4 on: November 06, 2017, 07:34:49 AM »
Is that a 1" or 3/4"?
Dandb7
« Reply #5 on: November 06, 2017, 05:51:37 PM »
Does that track just fit right on the 550 without any modifications or special adjustments ?
1979 Kawasaki Drifter 440
1989 Arctic Cat Pantera 440
BornagianKawi
« Reply #6 on: November 06, 2017, 06:59:04 PM »
lug depth is .725. Yes, what little I drove the other one around, it"s like shut up and hang on. Maybe make Duluth ski hill ? Yes, mods on drives, I took a drive out of 340 Invader, drives fit perfect, located on shaft in right spot. 4.75 spread from center of drives. Two outside idler wheels, moved to outside of lugs, used 2 collar assy. to hold in place. Left pipe spacer between drives. Suspension will have to move idler wheels to run by lugs not on lugs.
