Author Topic: The Intimidator  (Read 338857 times)
0 Members and 12 Guests are viewing this topic.
Re: The Intimidator
« Reply #75 on: February 09, 2018, 03:21:52 PM »
Welding
Re: The Intimidator
« Reply #76 on: February 09, 2018, 03:23:03 PM »
Before and after blasting
Re: The Intimidator
« Reply #77 on: February 09, 2018, 03:26:29 PM »
All painted
« Last Edit: February 09, 2018, 03:28:56 PM by gixxer6 »
Re: The Intimidator
« Reply #78 on: February 09, 2018, 03:30:19 PM »
Here it is with the pipes installed.  Can you guess which one was repaired?  I guess you could say it’s “done”, although complete, or assembled is probably a better discription.
Re: The Intimidator
« Reply #79 on: February 09, 2018, 04:59:36 PM »
That looks REALLY nice!!
Re: The Intimidator
« Reply #80 on: February 09, 2018, 06:30:39 PM »
Best of luck with the racing this weekend.
Re: The Intimidator
« Reply #81 on: February 09, 2018, 09:08:41 PM »
Not going to make the race.   :( the motor needs to come back out.
Re: The Intimidator
« Reply #82 on: February 10, 2018, 08:36:01 AM »
what kind of damage did the pipe have?
Re: The Intimidator
« Reply #83 on: February 10, 2018, 12:13:21 PM »
It was rusted through where the radiator shroud drips on it when it rains.  You can see the putting and holes in the first pics on page 5.  There was also an impressive mouse nest inside along with a dead mouse  :o
moz_21
Re: The Intimidator
« Reply #84 on: February 11, 2018, 08:03:35 AM »
Oh no, what happened? Sled looks great BTW. Definitely a direction I'd like to go, eventually.
Re: The Intimidator
« Reply #85 on: February 11, 2018, 08:36:05 AM »
The stator has a bad pulser coil.  I tried to remove flywheel with motor still installed ended up cracking the case.
Vader440
Re: The Intimidator
« Reply #86 on: February 11, 2018, 02:51:29 PM »
Sorry to hear that. I can only imagine your disappointment when that happened.  :(
Re: The Intimidator
« Reply #87 on: February 11, 2018, 02:53:44 PM »
Oh no!!!  I'm a little grumpy too but that is a story for another thread.
Re: The Intimidator
« Reply #88 on: February 14, 2018, 06:34:49 AM »
It runs!  Motor out, new stator installed and replaced the cracked flywheel housing, motor back in, timing set.  Whew, that was easy (sarcasm...)   :o
Now I just need to figure out what I did wrong with the mag side carb.  It's only running on one cylinder.   :(
5kaws
Re: The Intimidator
« Reply #89 on: February 15, 2018, 11:02:28 AM »
Nice job! Good luck!!
