Author Topic: Which 440 fan motors have the same jugs and bottom end as the intruder?  (Read 10882 times)
rogers26
Thanks for the add!  I have a intruder and was wondering if the drifter 440 is the same motor
« Last Edit: November 22, 2017, 06:36:07 AM by rogers26 »
Re: Fan motors
« Reply #1 on: November 21, 2017, 07:42:29 PM »
Welcome to the site!!!  They have some things in common but for the most part are not the same.
rogers26
Re: Fan motors
« Reply #2 on: November 22, 2017, 03:35:52 AM »
Really want to build a couple fan motors for oval racing and need to know if the crank , jugs and heads are the same?  intruder, drifter, or other models
« Last Edit: November 22, 2017, 06:31:29 AM by rogers26 »
Re: Which 440 fan motors have the same jugs and bottom end as the intruder?
« Reply #3 on: November 22, 2017, 01:38:17 PM »
Intruder jugs are set up for twin carbs and the jugs can be on either side.  Drifter jugs are set up for 1 carb and the cylinders are only left or right.  I've never tried it but the bottom ends may work for both.
rogers26
« Reply #4 on: November 23, 2017, 04:27:14 AM »
398. Thanks  I am new with kawasaki but ready two learn
« Reply #5 on: November 28, 2017, 04:05:23 AM »
 Intruder jugs will fit just fine on a Drifter bottom end.
 Any of the T7 engines can swap jugs.
