Author Topic: fuel line/belts/seals  (Read 14555 times)
« on: December 21, 2017, 02:56:15 PM »
where do you all buy the correct fuel line,7/32, the good stuff. I'm not set up as a sled shop anymore and lost my access to the basics. also, what do you use to replace the 1078 belt.
Re: fuel line/belts/seals
« Reply #1 on: December 21, 2017, 04:42:10 PM »
www.mfgsupply.com
https://www.mfgsupply.com/media/catalog/product/cache/1/image/1000x/c1eafbadb87a261db73e07c2de8fe883/h/p/hp3012_2.jpg
This is where I got my last new belt. Seems at least as good as the 1078 was....and the price isn't bad.... 8)
I would also like to hear if anyone has found some decent 7/32 fuel tubing....everything I have found is the plain, old vinyl that starts to get hard within 1 year.... :(
« Reply #2 on: December 22, 2017, 02:24:58 PM »
In the past I used Tygon tubing. I've never had a problem with it but it is expensive.
« Reply #3 on: December 22, 2017, 04:39:09 PM »
This is not 7/32.  However a few years ago we had a problem with fuel leakage.  We switched to this smaller line.  It takes a little stretching to get it over the fittings, but we have not had any problem with fuel leakage since we started using it.  Unfortunately I don't remember where I bought it.
« Reply #4 on: December 23, 2017, 11:06:08 AM »
I have been using regular black automotive fuel line.   lasts for years.
« Reply #5 on: December 24, 2017, 02:10:14 PM »
 Parts unlimited their fuel lines seem to be good used this stuff for years the
blue polyurethane fuel line [0706-0106] PARTS UNLIMITED They have other sizes too.
http://www.parts-unlimited.com/products/?productId=432898&partNumber=07060106
« Reply #6 on: December 26, 2017, 03:53:46 PM »
you get by with 1/4 on hi perf sleds?
DougKauer
« Reply #7 on: December 27, 2017, 06:45:16 AM »
I have some of that 7/32 fuel line if you need it. It's new, the color is yellow. PM me if you need some.  Doug
Vader440
« Reply #8 on: December 27, 2017, 09:09:31 AM »
I would like to replace the oil injector lines. Where can I purchase that? Thanks!
« Reply #9 on: January 28, 2018, 01:56:47 PM »
I was doing a little fishing for some other things and tripped over this cross reference for the 1078
http://www.daycoproducts.com/parts?category_id=1139&year=1980&make=46&model=5197&description=12414
According to Dayco they are referencing the HP 3012  at 46.69" long and 1.25" wide
« Reply #10 on: January 29, 2018, 01:28:31 PM »
i just used a hp3012, worked good
