Author Topic: Rear Suspension questions  (Read 8069 times)
chaddyg8
« on: January 06, 2018, 06:21:34 PM »
Now that my 78 invader is running!! My rear slide Suspension has virtually no up-and-down movement? I had the Suspension  off no cracks or anything but where should I start looking? When the  suspension was out I stood on the Pivot points and the shock had quite a bit of resistance And the spring. Thanks for any help.
Vader440
Re: Rear Suspension questions
« Reply #1 on: January 06, 2018, 06:47:17 PM »
There are shafts that go through the swing arms. They are probably froze up. I have the same problem with mine but haven't taken it apart to verify. I'll do that when warmer weather comes back.
chaddyg8
« Reply #2 on: January 06, 2018, 07:08:01 PM »
Everything seems to move? And I Greased eveytning when I  reassembled. Hmmmm
Vader440
« Reply #3 on: January 06, 2018, 07:23:46 PM »
Let me know if you find something, like I said I have the same problem.  :-\
chaddyg8
« Reply #4 on: January 06, 2018, 08:03:12 PM »
Will do 👍
