Author Topic: Kawasaki Intruder Performance  (Read 12344 times)
Bardtj
  • Guest
« on: December 21, 2012, 09:58:39 AM »
I have a 79 Intruder 440 that I'd like to get the best setup on. I would like to maximize this sleds speed and handling potential. Any tips?
Re: Kawasaki Intruder Performance
« Reply #1 on: December 21, 2012, 10:07:48 AM »
Balance the carbs. Probably the most overlooked thing to do.
And of course you replaced the crank seals right???
Also, clean out the clutch, new belt, make sure the rear suspension moves right, check for cracks in the suspension brackets, check ski wear bars, maybe replace them with carbides, Had enough yet??
Plenty of things to verify on a newly acquired sled.  "best setup" depends on what type of riding you are planning on, and where you are located.
Of course your sled will always run better after you post some pictures of it on here... 8)
P.S. Welcome to the club!!
« Last Edit: December 21, 2012, 10:13:23 AM by jimvw57 »
« Reply #2 on: December 21, 2012, 10:12:47 AM »
Do all maintenance before you modify anything.  As Jim said, balance the carbs, change the crank seals, clean the air box and carbs.
The best mod I have ever done to a Kawi is to put on a better track, and intall carbide runners on the skis.
