Author Topic: cylinder compression  (Read 49358 times)
Re: cylinder compression
« Reply #15 on: February 14, 2018, 12:17:26 PM »
I have heard from a good source that the rings that Image sells are chrome.  Chrome rings are NOT compatible with chrome bores.
While dual rings are better for our application, the single ring design is proven to work good in the 550.  As long as the ring and bore materials are compatible.
In my opinion you have 4 options:
1.  find NOS pistons and rings
2.  have your cylinders nicasiled
3.  have your cylinders steel sleeved
4.  Use the other single rings & pistons that are available that do not have chromed rings.  (unfortunately these rings will not fit on the pistons Image sells)
snowcross
« Reply #16 on: February 15, 2018, 03:48:09 PM »
hmm ok thank you gixxer6 .....
question... the chrome cylinders have been lightly honed .(not by me) .thinking they were the same as nicasil ...I'm guessing that is not the case.
Have these cylinders been damaged now?...can I go back to stock pistons and rings ?
I"ve taking my shellacking... now just trying to get things back on track .  >:(
« Reply #17 on: February 15, 2018, 07:40:42 PM »
While it’s controversial I’ve had great success lightly honing chrome bores.
You can certainly go back to stock pistons.  I sent you a PM about a source for stock style pistons.
« Reply #18 on: February 16, 2018, 08:16:38 AM »
I prefer acid wash but if you can,t feel a ridge should be fine...I,d like that piston info also please
« Reply #19 on: February 16, 2018, 09:41:06 AM »
The local-ish guy that bought these from me went another route.  He wants what he has into them (same price that it in the original ad).  He might also have NOS rings to go with them at an additional cost, he is going to check.  If anyone is interested PM me and I'll send you his phone#.
http://kawasakitrax.com/kawiforum/index.php?topic=1751.msg11250#msg11250
snowcross
« Reply #20 on: February 16, 2018, 04:49:35 PM »
so would it be correct to say OEM rings would (not) be chrome plated ?
considering the stock cylindersare chrome plated .
« Reply #21 on: February 16, 2018, 08:15:12 PM »
There are cast iron.  The rings need to be softer than the cylinder plating.  You may have 1 more ring option but I need to do some research before I say for sure.
« Reply #22 on: February 19, 2018, 11:10:05 AM »
you have to look at the rings, I have a single ring & thats moly & thats OEM cast Pistons
snowcross
« Reply #23 on: February 19, 2018, 06:55:40 PM »
before i have cylinders nic plated ...would anyone have 1 stock (550) used piston and rings perhaps sitting on there shelf and willing to sell?
any help would be greatly appreciated l
« Reply #24 on: February 19, 2018, 07:15:18 PM »
Do the jet ski pistons have 2 holes near the top of the piston?  Just trying to confirm what you have?
snowcross
« Reply #25 on: February 20, 2018, 07:50:57 AM »
I do have that type from image ...also a set without the holes at the top .... at the moment I'm looking for a stock kawasaki piston with 2 rings
snowcross
« Reply #26 on: February 20, 2018, 07:56:06 AM »
Kawasaki interceptor stock piston
snowcross
« Reply #27 on: February 20, 2018, 07:59:35 AM »
sorry they loaded in sideways
