Author Topic: headlight  (Read 15013 times)
BornagianKawi
headlight
« on: March 10, 2018, 08:48:12 AM »
So if I disconnect the headlight and run, will this mess up any of the rest of electrical? The reason I"am asking is, I purchased a headlight cover from chattanooga fiberglass, to put on. Going on 78 Invader.
« Last Edit: March 10, 2018, 08:50:45 AM by BornagianKawi »
Re: headlight
« Reply #1 on: March 10, 2018, 09:06:00 AM »
No.
BornagianKawi
Re: headlight
« Reply #2 on: March 10, 2018, 09:20:10 AM »
No, as in no problem. Or No, as in don"t do.
Re: headlight
« Reply #3 on: March 10, 2018, 09:40:30 AM »
Should not be a problem.  It would be the same and running the sled with the key in the "lights off"  position.
Re: headlight
« Reply #4 on: March 10, 2018, 11:07:03 AM »
No.   ;)
BornagianKawi
Re: headlight
« Reply #5 on: March 10, 2018, 06:09:29 PM »
Thanks guys.
Vader440
Re: headlight
« Reply #6 on: March 10, 2018, 06:20:43 PM »
Along those same lines, I read in the service manual to not run one that has an electric starter without a battery. But mine hasn't had a battery since I got it and it runs fine. In fact the previous owner said he had taken the battery out a few years ago. Am I damaging anything?
Re: headlight
« Reply #7 on: March 10, 2018, 08:37:09 PM »
Check  your voltage regulator.  If you have the electric start regulator then you have been very lucky.  If the regulator has been changed to a non-electric version that would  explain why the lights work with no battery.
Vader440
Re: headlight
« Reply #8 on: March 11, 2018, 10:04:37 AM »
Okay, Thanks!
Re: headlight
« Reply #9 on: March 12, 2018, 08:39:59 AM »
no battery/ for sure the rectifier is toast
