Author Topic: Anyone Know Anything About Honda Aquatrax?  (Read 22136 times)
« on: August 13, 2018, 05:20:25 PM »
I realize that Honda Aquatrax are not Kawasaki and not even snowmobiles, but over  the years I have found that this forum is an incredible resource for many things.  So I am taking a chance that someone knows about these water craft.
This past week our 2004 1200 turbo melted some of the waterbox.  The waterbox, as I have learned that it is called is the last part of the exhaust system and is plastic.
So question 1, does anyone know about Honda Aquatrax?
Question 2 is, does anyone know about melted waterboxes?
Re: Anyone Know Anything About Honda Aquatrax?
« Reply #1 on: August 18, 2018, 07:28:56 AM »
A melted waterbox means you're not getting water through it too much hot exhaust & not enough water. I'd take your water inlet off then blow through the line with a air chuck. What happens to a lot of pwc they sit on the sandy beach then collect sand through the inlet causing less water to pass through the engine. There is a water bypass (hose) that goes to the exhaust manifold to the water box that might be plugged either blow it out or replace it. When blowing air through the inlet you should be able to feel the same amount of pressure going out.
« Reply #2 on: August 18, 2018, 07:40:57 AM »
The water box is your muffler most of them are made out of smc (plastic fiberglass) materials the aftermarket company's make them out of aluminum but these are much louder some states have a decibel reader where the exhaust can not exceed a certain number check with your local dnr on that. The aluminum water box will make more power but it will also add more noise. I've never worked on the Hondas or any of the newer models that have turbo or 4 stroke engines but I've had my fare share of jet skis & know what to look for, have anymore questions let me know I'll see what I can do
« Reply #3 on: August 18, 2018, 09:48:47 AM »
Thanks for the input.
I am waiting for a manual hoping that will show me more detail on the water path.  We have another lake outing scheduled for Labor Day and I am wanting to get it back in business for that event.  But with only this weekend and next weekend, today i plan to start disconnecting and inspecting hoses.
« Reply #4 on: August 18, 2018, 11:16:51 AM »
Here are some photos.  It is a little difficult to see.  The plastic exhaust elbow is deformed and there is plastic coming out of the water box.
« Reply #5 on: August 18, 2018, 12:54:33 PM »
for some reason the photos are not uploading.
I started at the inlet, which i believe is in the jet housing.  This is clear up to the check valve.  The check valve is clear.  Now I am moving farther forward.
« Reply #6 on: August 18, 2018, 05:43:48 PM »
Still can't get any photos to upload.
I have the exhaust out.  Both chambers are clear.  The water hoses have free passage from the check valve up through the intercooler, through the turbo and through the exhaust.
So far I have not found any grit or crud.
« Reply #7 on: August 19, 2018, 08:11:44 AM »
How large are the pictures?
« Reply #8 on: August 19, 2018, 10:46:15 AM »
Looks like they may be too big, I just checked them and see that they are between 3 and 5 MB.  I will try to get them smaller.
« Reply #9 on: August 19, 2018, 10:52:07 AM »
I will try gain with smaller photo files
« Reply #10 on: August 19, 2018, 05:26:21 PM »
I can see them!
« Reply #11 on: August 19, 2018, 09:24:14 PM »
I can see the pics the other 2 things that can cause the water box to melt is being clogged or check valves are setting themselves to default (CDI box) that controls the check valves to open or close.
The water inlet was just something that happened to me years ago where it costed me to pass on the finals of a race I was at no water came out of the water by pass & you could've fried a eggs & bacon on the cylinder head it was that hot.
« Last Edit: August 20, 2018, 06:46:30 AM by sprocket »
« Reply #12 on: August 22, 2018, 05:27:38 PM »
So far we have traced out each of the water passages.  All clear.  Between the inlet and the exhaust I am only seeing one passive check valve.  And again, that circuit is all clear.  At this point I am putting it back together and plan to put it back on the hose to see how everything responds.
« Reply #13 on: August 24, 2018, 04:37:17 PM »
Now I am completely confused. Took apart as many hoses as I could reach. All clear with no debris. Pulled off the resonator and checked as much as I could inside the exhaust manifold cooling jacket. All clear with no debris. Blew through everything with air and no evidence of restrictions. Put it all back together and ran it on the hose for about a half hour. Temperatures stabilized nicely just under 100. Highest temp measured was on the hot side of the turbo at about 125. Water coming out of the weep hole, out of the water box and some out of the jet. I assumed the latter was leaking past the check valve. No water leaks inside of the hull. At this point I don't know what else to do except put it back in the wate
« Reply #14 on: August 25, 2018, 10:43:00 AM »
Sounds like time to drive it.
