Author Topic: 78 invader 440 does not start  (Read 14793 times)
invader 440
« on: December 31, 2012, 09:58:01 PM »
Hi guys ive been trying to get my invader running. i replaced the crank seals and i got it to run afterwards untill antifreeze started coming out of the head. so i got a new top end gasket set to reseal it all. now i cant get it to start. also the fuel pump doesnt look like its pumping enough gas. Even after i cleaned it and made sure everything was clean. Any ideas of what is wrong? Thanks
« Last Edit: December 31, 2012, 10:00:03 PM by invader 440 »
Re: 78 invader 440 does not start
« Reply #1 on: January 01, 2013, 02:05:04 PM »
what size line are you using? 3/16 is tight and hard to put on but wont leak 1/4 will leak and you wont get a good pulse
invader 440
« Reply #2 on: January 01, 2013, 07:03:49 PM »
I  have 1/4 line. the one thing i dont understand is that when i even put gas down the carbs it wont even pop.
bryan_damone
« Reply #3 on: January 01, 2013, 07:31:51 PM »
Its a good idea to check all the basics if you haven't already and report back.
Is there spark?
Is there compression?
Is there fuel?
If you have no pop with gas in the cylinders, you may have a spark or compression issue.
« Reply #4 on: January 01, 2013, 08:00:51 PM »
is there fluid in the pulse line?  Try putting a finger on the pulse line and see if you have a 'pulse'  Maybe  you lost a crank seal or crankcase seal along  the case halves.
One more really dumb one (don't get mad) is there gas in the tank? (been there)  or fouled plugs??
Back to basics.. fuel spark, compression. as Bryan said
invader 440
« Reply #5 on: January 01, 2013, 09:06:50 PM »
I will have to check the pulse line tomorow. i put a extra gallon in the tank before i tryed to start it.  the spark is strong but what would of knocked the timing off since i last ran it and only put the recoil back on.
« Reply #6 on: January 01, 2013, 10:59:57 PM »
could be the spark coil shifted which would throw off the timing. You'd still get spark, just at the wrong time.  Maybe a bad connection at the connector on the cover by the recoil??
