Author Topic: motors  (Read 143150 times)
mgd316
motors
« on: December 26, 2020, 05:25:59 PM »
i need help figuring out what i got the serial number on the block tc440d 000001 there is a us pat number  also any help would be great thank
Re: motors
« Reply #1 on: December 27, 2020, 06:36:27 AM »
TC440D means it’s an 81-82 440 LTD motor.  I’m confused by the “0000001”, the model identification section says the 82 serial numbers start at 17...  http://kawasakitrax.com/82models.htm
72SSRS
Re: motors
« Reply #2 on: December 27, 2020, 07:31:04 AM »
This is serial # on a prototype 530 Interceptor motor.   No pat sticker or any numbers or letters other than the Xserial #.   Ribs on cyls and Head are completely different than stock/factory run set of heads and cyls.  Everything was marked 530 tho.
mgd316
Re: motors
« Reply #3 on: December 27, 2020, 09:17:31 AM »
following up looked on motor i have theses numbers s3-a then tc440d -000001 then a gold stamp us pat.4114586 then on the jug i have 530/2a thats all i can see thank you for your help
Re: motors
« Reply #4 on: December 27, 2020, 07:02:04 PM »
Welcome to the site!!  It is not real uncommon to see 550 jugs on a 440 mono head bottom.  Serial number 1 needs some further study.
mgd316
Re: motors
« Reply #5 on: December 27, 2020, 07:43:42 PM »
thank you just trying to figure this thing out  the 01 is confusing me and thank you
Re: motors
« Reply #6 on: December 28, 2020, 07:55:51 AM »
Is this motor in a sled?  If so, what are the numbers stamped on the right foot area of the tunnel?
mgd316
Re: motors
« Reply #7 on: December 28, 2020, 12:51:12 PM »
yes it is the tunnel is scrtched right there but i see ss440a-?c17 or the c could be a 6  thank you for your help
Re: motors
« Reply #8 on: December 28, 2020, 05:33:25 PM »
Can you buff it up a bit and get a picture of that number to post??
mgd316
Re: motors
« Reply #9 on: December 28, 2020, 06:10:51 PM »
ill try plus i wanted to post the pic of all the numbers i have but havent figured out how to post them yet and thank you
mgd316
Re: motors
« Reply #10 on: December 28, 2020, 07:17:18 PM »
picture of the motor
mgd316
Re: motors
« Reply #11 on: December 28, 2020, 07:24:47 PM »
picture of serial number on the motor
72SSRS
Re: motors
« Reply #12 on: December 28, 2020, 08:50:34 PM »
Take a picture of the primary clutch and complete sled .  Definitely a invader chassis cause of tool box and heat shield apparently is metal and homemade cause looks like it’s all rusty. Definitely 550 head in the picture.
Re: motors
« Reply #13 on: December 29, 2020, 09:07:07 AM »
The bottom end may be the 1st one. :) :D  The TC440D covered 81 and 82 LTD motors.The TC530D for the 550 is pretty much the same bottom.  I have seen one other 550 stuffed into an Invader chassis and from what I heard it was plenty of farting around to get it to work.  It would be a great "sleeper" sled.
mgd316
Re: motors
« Reply #14 on: December 29, 2020, 05:36:02 PM »
thank you for the help now i have to figure out what to do with it
