Author Topic: Coolant system question  (Read 7225 times)
Vader19
« on: February 28, 2021, 06:38:35 AM »
I have put my motor back together following a crank seal replacement and I am starting to address another issue.  This sled appears to have had a lot of coolant leaking from both the pump side as well as the transfer ports on the front of the engine.  It looks like the gasket kit I bought has new gasket for the front port but nothing for the water pump.  Should I use a gasket material on the water pump and those gaskets on the front ports?
Re: Coolant system question
« Reply #1 on: March 02, 2021, 12:06:36 PM »
The water pump uses an o-ring to seal to the motor.  You should be able to find a replacement oring.
