Author Topic: Immediate help needed!  (Read 7127 times)
whitley1983
« on: March 04, 2021, 02:28:07 AM »
Can anyone tell me the length of the bolt for the drain on the gear case on the 78 invader? Parts manual says it’s a 6 x 10 mm. Mine rattled out and our vintage race is this weekend!
« Last Edit: March 04, 2021, 02:33:32 AM by whitley1983 »
Re: Immediate help needed!
« Reply #1 on: March 04, 2021, 08:36:37 AM »
Engine or chain case??
« Reply #2 on: March 04, 2021, 08:59:15 AM »
6 x 10 sounds right to me for the gearcase on the engine.  the 10 would mean 10 mm long just a little over 3/8".  Don't forget to use an aluminum seal washer.
If it is the chaincase then i actually think those might be tapered threads and are a bit bigger than 6 mm diameter.  And, if I remember correctly the chaincase plugs are plastic.
« Reply #3 on: March 04, 2021, 09:53:20 AM »
6mm X 1.0 pitch  X 10mm long and like mswyka says be sure to use the washer.
whitley1983
« Reply #4 on: March 04, 2021, 03:35:16 PM »
Awesome thanks!!
