Author Topic: Electric water temp guage  (Read 8377 times)
Ameritude
« on: August 27, 2021, 12:50:29 AM »
Might be a stupid question, but I'm wanting to put an electric water pump gauge on my sled, but it needs a 12v source, do you guys know of any way to make this work without a battery. If someone has done it with a battery, was it difficult, im not against it but simplicity is better.
Thankyou in advance
Re: Electric water temp guage
« Reply #1 on: August 27, 2021, 08:24:41 AM »
Why use an electric gauge?  I've had really good luck with the Bosch aftermarket temp gauges.
To use my large automotive tach on the Intimidator, I added a voltage regulator with rectifier from an e-start sled and a small lead acid battery.  It's not ideal, but it works.
Ameritude
« Reply #2 on: August 27, 2021, 12:27:22 PM »
My original reason is because you can hide wires alot easier than a line but maybe simpler is better.
