Author Topic: Occasional backfire  (Read 12775 times)
bryan_damone
Occasional backfire
« on: January 06, 2013, 07:11:47 PM »
So I have been out on my 440 invader for the first time since resealing and giving all systems a good inspection during the non-winter of 2012.
After taking it easy until warming up, I would get on the throttle and everything would seam as it should, but sometimes when coming of the throttle suddenly at the end of the yard to make a turn, it would sometimes backfire.
Running stock carbs, jetting, airbox. Exhaust is all intact.
What are your thoughts on this?
Re: Occasional backfire
« Reply #1 on: January 06, 2013, 07:18:13 PM »
I had that happen once and it was a bad connection to the cdi
« Reply #2 on: January 07, 2013, 11:19:20 AM »
Every time one of our sleds would backfire we had a crank seal issue.
bryan_damone
« Reply #3 on: January 08, 2013, 11:43:27 AM »
This is promising. I just found that the lighting coil connections were loose (lost lights), so it makes sense that I may have other loose connections in that area. I will recheck all connections from stator.
