Author Topic: Scraping the Bottom of the Barrel  (Read 16352 times)
« on: March 07, 2022, 06:08:26 PM »
Looking to put together another pair of skis for the 82 Intruder.  We have three that sort of match, but each one has issues.  The best of the three has a kink in the front loop.  I can probably live with that.  The second best has a different style loop and a few holes in the underside just about where the ski starts to curl up off the ground. The third has a great front loop but looks like swiss cheese on the bottom.  I want to try to avoid buying another sled just to get a ski.
Re: Scraping the Bottom of the Barrel
« Reply #1 on: March 08, 2022, 07:01:57 AM »
Can you weld?  You may be able to remove the ski loop from the battered ski and replace the one with a kink in it?
Those look like 81' Invader or 81-82 LTD skis.  Were they the same as the 82' Intruder?  I thought they had wider and taller springs than the Intruders?
« Reply #2 on: March 08, 2022, 05:06:09 PM »
I do have a MIG, but I don't consider myself an artistic welder.  Yes, I do believe that these came off of one or more LTD.  All of our Intruder skis look worse.
Joel
« Reply #3 on: March 08, 2022, 07:33:32 PM »
You know buying another sled just brings more potential ;D.
« Reply #4 on: March 08, 2022, 08:33:40 PM »
Spot on!!!!
« Reply #5 on: March 09, 2022, 07:29:31 AM »
The LTD ski's will be taller...Sounds like a great reason to buy another sled!
« Reply #6 on: March 09, 2022, 11:04:22 AM »
You guys are forgetting that I have to clean-out my storage space.  I have a 24 x 60 building dedicated to the sleds.  They are all going to need to find a new location.  And, since i don't have comparable available space, that means much of it will need to go to a new home.
« Reply #7 on: March 09, 2022, 06:42:04 PM »
You don't really think that story will work???  Or maybe go to a swap with wrenches and only take home the stuff you need???
