Author Topic: stock 81 invader track specs  (Read 22065 times)
NDHICK
« on: January 07, 2013, 08:59:20 PM »
Does anyone know what the stock invader track specs are or what newer tracks with a little longer paddles would work?
Re: stock 81 invader track specs
« Reply #1 on: January 08, 2013, 12:07:26 AM »
You don't want to go much more than 3/4 inch high with the paddles or they will hit the bulkhead (I have been told)  Same with studs.
« Reply #2 on: January 08, 2013, 02:27:32 AM »
I have put track on with 1" lugs with no issues and i think you can fit up to 1 1/4" in there
ChaChi
« Reply #3 on: January 08, 2013, 06:30:56 AM »
I bet a 1 inch lug paddle track is awesome in the deep stuff eh? Any difference in how it turns?
Do paddle tracks wear out quickly on road crossings?
NDHICK
« Reply #4 on: January 08, 2013, 09:00:12 AM »
What type of track did you use? is it a straight bolt on? we don't have much for trails where I live and all it wants to do is spin out and dig down in the powder.
« Reply #5 on: January 08, 2013, 02:30:23 PM »
I have used tracks from Polaris and Skidoo sleds and i usually took the outer wheels off the drive shaft and had to adjust spacing on a couple of the wheels but nothing major.
« Reply #6 on: January 08, 2013, 02:44:54 PM »
I put a 1" Camoplast Hacksaw track on my 81' Invader.  This was the best mod I have ever done to a Kawi.
Like Trucker said, some of the idler wheels needed to be repositioned.  However, I didn't remove the wheels on the drive, I repositioned them also.
NDHICK
« Reply #7 on: January 09, 2013, 02:34:58 PM »
Thank you very much for your help. I am going to start looking for a 1 inch track to get ready for my summer mods on this sled.
Mad Kaw
« Reply #8 on: January 10, 2013, 01:27:05 PM »
what did you guys use to space the rear wheels out?
« Reply #9 on: January 10, 2013, 03:17:55 PM »
I used parts from other sleds i parted out or just moved the little washers around a bit
Mad Kaw
« Reply #10 on: January 10, 2013, 03:50:42 PM »
after looking at it closer,,, it looks like a couple/few washers should do it...
for some reason it seemed like the rear wheels were closer to the windows than they are... (like they had to come out at least 1/2")
that and im probably just over-thinking it  ::)
« Reply #11 on: January 10, 2013, 04:03:07 PM »
It's been awhile, iirc I used a longer shaft in the rear with longer spacers.
Mad Kaw
« Reply #12 on: January 12, 2013, 12:35:34 AM »
yep,, all it needed was 2 more shims on each rear wheel... (good thing i had a 3 wheel skid laying around for parts)
the wheels actually measured 12" from inside to inside,, which is the same distance as the outside of the drive lugs,, the 2 extra shims on each side brought it to 12 1/4"... a couple adjustments to the alignment and it looks good to go...
picked this track up for $60... 192 studs (- pullouts),, all the clips are there & in decent shape,,, and looks to be pretty low mileage (all the nubs on the lugs are still there)... whatta deal,,, kinda feel like i ripped the guy off but that was his asking price...
