Author Topic: removing hand grips  (Read 13905 times)
menger69
removing hand grips
« on: March 06, 2013, 04:32:20 PM »
  I need to replace my throttel so what is the trick to remove the grips or is it easer to cut them off and buy new
Re: removing hand grips
« Reply #1 on: March 06, 2013, 04:37:24 PM »
I use and air blow gun to pop them off.
menger69
« Reply #2 on: March 06, 2013, 04:58:26 PM »
  I tried that dident work
invader87
« Reply #3 on: March 06, 2013, 05:07:23 PM »
move the throttle lever away from the grip. put an adjustable wrench next to the grip set just slightly larger than the bar. hit the adjustable with a hammer and knock the grip off.
menger69
« Reply #4 on: March 06, 2013, 05:34:35 PM »
  I got it off thanks for the help
« Reply #5 on: March 07, 2013, 02:00:27 PM »
Glad you got them off.
A secret of mine is to spray Aqua Net hair spray with a screwdriver forcing a small space.  I shove the screw driver on the top side and spray the hair spray such that it runs down and in the grip.
The grip comes off with some wiggling.  Back on the grip gets a squirt down the grip and she slips right back on.  Best it holds the grip on well.
