Author Topic: Hole in PTO piston  (Read 14472 times)
Hole in PTO piston
« on: March 08, 2013, 05:49:55 PM »
 This is the engine that is in my Sportfire. It is the engine that was originally in my 80 440 Drifter.
 I sealed it all up. passd pressure test. Put it in sled, Drove about 1 mile and burned a hole in the piston.
 Any ideas why it burned?
Re: Hole in PTO piston
« Reply #1 on: March 09, 2013, 06:55:39 AM »
Ouch!  Did it run really, really, nice right up until the point where it quit?
I have seen that piston a few times on our 440 Invader and always just after it seems to fly like a jet.  And, each time we found an air leak on the inlet that allowed the engine to run lean.
« Reply #2 on: March 09, 2013, 08:46:46 AM »
i say lean also.....what carb are you running?
« Reply #3 on: March 09, 2013, 08:49:50 AM »
Looks like it ran lean.  A lean condition is one of two things, too much air, or not enough fuel.  You did a pressure test, I would look at your fuel supply.  A plugged jet maybe?  Or a pinched fuel line?
« Reply #4 on: March 09, 2013, 06:05:46 PM »
Actually Mark it ran like crap before it burned.
 I know usually they never run better than just before they pop.
 Would you believe after it burned I still drove the sled home.(about 1500 feet)
« Reply #5 on: March 10, 2013, 02:36:07 PM »
Glad you made it home.  I always had to get towed.  Very embarrassing.
« Reply #6 on: March 10, 2013, 04:29:20 PM »
Back together and running much better today. Short run on probably our last sledding day
