Author Topic: Gas Tank conversion  (Read 27839 times)
Intrigued_440
Gas Tank conversion
« on: December 18, 2013, 04:51:21 PM »
Well my 340 invader gas tank is pooched, filler neck broke off and tried using PVC pipe. Didnt turn out right. So I was looking at the drifter gas tank and looked pretty much the same. Will that tank fit my invader?
My Sled's:
1980 Kawasaki Invader 340
Re: Gas Tank conversion
« Reply #1 on: December 18, 2013, 05:54:06 PM »
I think that you can make just about anything work.  The better question is whether or not you will like it.  I can recommend the replacement filler neck sold by Image.  They are easy to install and work great.  With the cap on no one can tell  the difference.
« Reply #2 on: December 18, 2013, 06:02:31 PM »
They are not an exact replacement.
Intrigued_440
« Reply #3 on: December 18, 2013, 06:19:41 PM »
Hmmm, do they have a site that I can look at it? Im from Canada, so shipping and ordering online is iffy for me
My Sled's:
Intrigued_440
« Reply #4 on: December 18, 2013, 06:20:13 PM »
Would it fit if i did some mods?
My Sled's:
« Reply #5 on: December 18, 2013, 07:33:56 PM »
Like Mark said, anything will fit if you mod it enough.
The Image kit is very nice, and much stronger than the stock threads.  http://www.imageenterprises.com/kawasaki-parts-for-sale.cfm
Intrigued_440
« Reply #6 on: December 18, 2013, 09:34:10 PM »
If I were to order it, how much do they charge? And what would that be in CAD?
My Sled's:
« Reply #7 on: December 19, 2013, 12:19:47 AM »
Last neck I replaced was a few years ago. Not bad to do, it involves cutting off the old neck (or what is left of it) and making the surface flat (or smooth) and putting the replacement neck in place with an o-ring seal underneath, drilling 6 screw holes in the tank to attach it and you are done.  With the gas cap in place, the mount is completely hidden, and the replacement neck is much stronger than the original one.
Not sure on the price but I think Image Enterprise is the only place that has them.   The other option is to fin a replacement tank, but a cracked neck is real common problem.
« Reply #8 on: December 19, 2013, 07:28:07 AM »
Last time I bought a kit it was $45USD plus shipping.  The last time I sold a tank with good threads, I sold it for $60.  But as far as I can tell, its only a matter of time before they all break.
« Reply #9 on: December 19, 2013, 08:18:05 AM »
some of my sleds still have good threads,but most don't. that drifter tank is to small, shaped wrong, will look like shizzzz
flatlander
« Reply #10 on: December 20, 2013, 06:47:14 AM »
I just purchased the filler neck from Bob last week and I think it was $50 something but I wanted a quick fix and I guess you just pay the piper.  Cut the old one off and sanded the surface smooth.  I elected to glue mine with a 3M 2-part epoxy versus the screw route.  I think it looks much nicer than a circle of screws.
« Reply #11 on: December 20, 2013, 10:59:28 AM »
with the cap on you don't see the screws (unless they have changed) and any glue usually needs a super clean surface to get a good grip. The plastic can absorb  the gasoline and is tough to get clean. Hope it works out for you.
« Reply #12 on: December 20, 2013, 12:05:01 PM »
those kits are the way to go
F500-92
« Reply #13 on: December 30, 2017, 10:48:56 PM »
I picked up an Invader a week ago with a similar issue.   I sent an email to the link above.  Anyone know if they still make it or should I look for other options?
« Last Edit: December 30, 2017, 10:53:22 PM by Sully »
« Reply #14 on: December 31, 2017, 08:50:42 AM »
 Bob at Image Enterprises is winding down a bit,....but still in business.
Contact his web site....you can still order the repair kit for the fuel tank.
