Author Topic: Invader Light Problem  (Read 10686 times)
Intrigued_440
« on: January 06, 2014, 05:15:42 AM »
Well I was running in the ditches thursday night and the headlight and dash lights worked perfect. Now I went out and run it and the headlight and the gauge lights arent working. The headlight bulb had both ligaments gone, so I switched a bulb from my other sled and the light still doesnt work. Any things I should look at?
My Sled's:
1980 Kawasaki Invader 340
Re: Invader Light Problem
« Reply #1 on: January 06, 2014, 05:48:48 AM »
Check your wiring harness connections on the back of the key switch and at the engine.  These often vibrate loose.  If the lights worked properly with steady output and you had no problems running at night right up until you stopped it is unlikely that they burned out.  If the intensity varies with engine speed check the ground on your voltage regulator.
« Reply #2 on: January 06, 2014, 09:28:55 AM »
if the 2nd bulb is fried look at the v reg....next i'd look at the 5 blade connector  under the radiator.
