Author Topic: Invader Crank Case Spec  (Read 11425 times)
Winter Thunder
« on: January 15, 2014, 10:06:52 PM »
Anyone know the torque specs on the crankcase bolts on an 81 Invader and/or have a picture they could post of the bolt tightening pattern?  Just put in new crank seals and need to clamp it back together.
Re: Invader Crank Case Spec
« Reply #1 on: January 16, 2014, 02:27:03 PM »
For the stock Invader the manual says "16 ft-lb in 1/3 increments in criss-cross pattern."  And while I am reluctant to argue with Kawasaki engineers, I don't think that 16 ft-lb is enough and take mine up to 20 ft-lbs.  The LTD may be different, I don't have that manual handy at the moment.
« Reply #2 on: January 16, 2014, 02:59:27 PM »
I've done the 16 ft-lbs on all my sleds and have never had a problem.
« Reply #3 on: January 16, 2014, 03:15:42 PM »
and a little drop of red locktite.... :D
