Author Topic: Gas coming out carb vent tube on invader  (Read 11436 times)
Winter Thunder
« on: January 19, 2014, 12:14:35 PM »
While running my invader I have gas running out one of the vent tubes on that right side carb.  Would a stuck needle cause that?
« Last Edit: January 19, 2014, 06:03:20 PM by Winter Thunder »
Re: Gas coming out carb vent tube on invader
« Reply #1 on: January 19, 2014, 12:57:04 PM »
yup. If it leaks while motor is off, also a needle and seat (or float setting) and possibly valve in the fuel pump (anti-siphon valve)
« Reply #2 on: January 19, 2014, 01:19:16 PM »
probably some crap under the seat
Winter Thunder
« Reply #3 on: January 19, 2014, 06:00:24 PM »
Pulled the carbs and found the needle stick up in the seat.  Got it cleaned out and works like a champ now.
« Last Edit: January 19, 2014, 06:04:05 PM by Winter Thunder »
