Author Topic: Mikuni bog  (Read 14728 times)
thomy
Mikuni bog
« on: January 31, 2014, 03:43:57 PM »
Has anyone been successful putting Mikuni VM roundslide 38mm carbs on the Interceptor? That is, have you been able to tune out the low to mid bog? If you have would you please share the components you used to get there?
I've got this one ready for ovals racing except for this one minor detail of getting past the brief low end bog. Not conducive to a great hole shot.
Thom
Re: Mikuni bog
« Reply #1 on: February 01, 2014, 08:28:02 AM »
i picked up a set from BILLY G a while back and haven't run it yetbut they are ..38 bored to 39.5 i believe 3.0 cutaway, 42.5 pilot,370 mains, 66qo n jets, 6dh4 needles in the 4th from the top.i'm gonna rip it around the yard today, i'll check back with progress
Re: Mikuni bog
« Reply #2 on: February 01, 2014, 09:04:54 AM »
I wasn't able to get #553 to run without a bog with the 39.5 mikunis on it...
Re: Mikuni bog
« Reply #3 on: February 01, 2014, 10:42:28 AM »
 8) no mid rande bog or flat spots, when fully warm if i let it idle for 10 sec or so and i snapped the flipper hard to wot she'd bog and actually  try to die.... but not as hard and pow! track spinning rippin little bitch! points to consider... drive belt is ok but hardly new...i have not played with air screw or pilot jet yet....the intake bells on these are cut and beveled right to the air passages at the bottom of the venturi...dam its fun when the skis carry till you let off ;D
invader87
Re: Mikuni bog
« Reply #4 on: February 02, 2014, 02:20:34 PM »
change to 2.5 slide cutaways drop the needles all the way and give it a try. just my two cents. let us know !!!
