Author Topic: Different ratios  (Read 13623 times)
Habbeli
Different ratios
« on: February 07, 2014, 03:56:26 PM »
I looked at different ratios to my Intruder, why is it empty slots in the table for some ratios?
Re: Different ratios
« Reply #1 on: February 07, 2014, 04:31:50 PM »
i would guess there is not a gear/chain combo that works well,just a guess....gearing down? how long a track?
« Reply #2 on: February 07, 2014, 05:12:24 PM »
  You should have a 1.86 in there...  just talked with a gentleman running 1.73 (half mile straights) LTD stock gearing.  You loose about 8% of your horsepower in overdrive...  you want to be close to a 1:1 for maximum efficiency.  I like to be just under the 1:1 at the end of the straight (depending on distance).  Try the black magic marker trick (both primary and secondary sheaves).
Habbeli
« Reply #3 on: February 07, 2014, 07:36:17 PM »
I am thinking about run with 19-38 then this applies to drag racing
We drive here in Sweden 150 meters in the veteranclass, so I think it would be pretty good
You're not going up more than maybe around 65 MPH  ::)
« Reply #4 on: February 07, 2014, 08:39:05 PM »
  Speaking of classes, I was entered in the 40-50 age category in my last race event.  I had to look twice at the age group I was in...  doesn't seem possible.  I feel like it was just a few years ago I graduated from high school!  In my head anyway (not so much in the physical department).
  You know, 65 mph is a safe speed - around here you'd only end up with a speeding ticket and a hefty fine for exceeding the  ("speed limit")!!  Good luck!
Habbeli
« Reply #5 on: February 09, 2014, 01:43:21 PM »
Here's how it looks when we play with our veterans scooters at 150 meters
http://www.youtube.com/watch?v=3gg_k7_1v-g&feature=youtu.be
« Last Edit: February 09, 2014, 02:21:28 PM by Habbeli »
