Author Topic: Resistor Plug Ends  (Read 12063 times)
58Evinrude
Resistor Plug Ends
« on: February 07, 2014, 05:55:15 PM »
Is there any reason that the plug wires have resistor ends at the plugs? Other than some sort of noise suppression, I can't see why resistors are there, especially with resistor plugs. I'm asking because I have a broken plug connector, and I just want to swap in a regular plug end.
Re: Resistor Plug Ends
« Reply #1 on: February 07, 2014, 06:05:13 PM »
When I replace plug ends. I use non resistor ends, never had a problem
58Evinrude
« Reply #2 on: February 07, 2014, 06:19:41 PM »
Thanks Lloyd. I didn't think it would be an issue, I'm just making sure :)
« Reply #3 on: February 08, 2014, 08:17:05 AM »
i use the 'coil spring type' for old outboards....and kaw didn't use resistor plug ends in the us
« Reply #4 on: February 09, 2014, 09:01:21 AM »
you can have problems if you have resistor ends on the cable and then use resistor plugs. You end up with too much resistance and it weakens the spark.
