Author Topic: Shock  (Read 12323 times)
cadee
Shock
« on: February 08, 2014, 02:40:45 PM »
i removed the suspension on my 1981 Invader and i lubed everything up because it was "bottioming out" and would not pop back up.
I took out the shock and my question is, how do i know if the shock is siezed?
i cant compress it by hand so this there some way i can tell if i can just lube it or something or do i have to buy another one.
Thanks!
Cpt. Kawi
Re: Shock
« Reply #1 on: February 08, 2014, 09:47:35 PM »
You should be able to move the shock back and forth by hand. Keep in mind the shock is just a dampener if it has no spring on it, so as to slow the suspension travel.
Snowmobiles:
81' invader 440
Motorcycles:
64' kawasaki B8t
71' Mt1 Parnell Jones #641 & #14276
72' ke 175
75' H1 500 streetfighter
77' kz1000
79' kz1000
85' ninja 900r
09' concours 14
Re: Shock
« Reply #2 on: February 09, 2014, 08:59:42 AM »
If you have the standard suspension, there is a coil spring on the shock. You need to compress the spring to remove the retainers from the shock shaft and then remove the spring.
If it is the Vari-ride suspension, there is no spring on the shock and it should move in and out slowly.
Re: Shock
« Reply #3 on: February 09, 2014, 11:47:11 AM »
Being an 81 Invader, it should have the Vari-Ride skid.  If someone has replaced the shock with an aftermarket gas shock, it will behave different than a hydraulic shock.  The gas shock will be fully extended and will push in hard, then slowly extend itself.
I think I have some good used shocks ( both gas and hydraulic) if you are in need.
Re: Shock
« Reply #4 on: February 09, 2014, 05:43:39 PM »
I have seen 81 Invaders with the wrong skid in them, probably a shade tree mechanic with a spare older version suspension that had to be used. I'd stick with the Vari-ride.
