Author Topic: Drivebelt Kawasaki Intruder  (Read 13456 times)
Habbeli
« on: March 11, 2014, 08:08:58 AM »
Anyone know what angle it is at the clutches?
I have driven with no name-belts and then the clutch be hot with some brands.
Which clutchbelt you recomend?
Re: Drivebelt Kawasaki Intruder
« Reply #1 on: March 11, 2014, 01:17:17 PM »
Check the clutch alignment.
thomy
« Reply #2 on: March 11, 2014, 01:37:53 PM »
I think that the best belt is Dayco HP3012 or the Max 1078. I've found that the cheaper lines of belts are not always the correct width. I wish they made a heavy duty version of this size.
Thom
« Last Edit: March 12, 2014, 01:41:59 PM by thomy »
Habbeli
« Reply #3 on: March 11, 2014, 09:55:52 PM »
It is 100% ok  ;) :D
« Reply #4 on: March 12, 2014, 08:27:05 AM »
i have good luck with top max 1078 ........if that number is still valid.
