Author Topic: Carb O - Rings  (Read 25088 times)
58Evinrude
Carb O - Rings
« on: March 28, 2014, 03:39:30 PM »
Does anyone know what size these are? I'm talking about the little guys that go into the bottom of the carbs on a 440 Intruder.
Thanks in advance
Re: Carb O - Rings
« Reply #1 on: March 29, 2014, 07:14:29 AM »
 It's hard to find one that fits right.
 Mikuni part number BV3204
 Newbreedparts.com has them.
 Any small engine shop should be able to get them
thomy
Re: Carb O - Rings
« Reply #2 on: March 29, 2014, 01:25:29 PM »
14-2215 is the Western Power Sports part number but they only sell them in a 10 pack
BV32/04 is also the Marshall Distributing part number.
Usually dealers will sell them individually.
Polaris part number is 3130015.
58Evinrude
Re: Carb O - Rings
« Reply #3 on: March 29, 2014, 11:35:26 PM »
Thanks for the info... I bought a pack of 225 today.. somewhere in there should be ones that fit :)
Re: Carb O - Rings
« Reply #4 on: March 30, 2014, 06:46:31 AM »
Seems like the ones in the fuel pump rebuild kits are the same size??
58Evinrude
Re: Carb O - Rings
« Reply #5 on: March 30, 2014, 10:11:47 AM »
For what fuel pumps? There's no o-rings in the rebuild kit I bought for my Mik pump.. none in the pump either.  But then again, there's no diaphragm in the re-build kit either  :( I got lucky and found a dual outlet pump in my parts collection that works  :)
bryan_damone
Re: Carb O - Rings
« Reply #6 on: April 02, 2014, 08:26:51 PM »
5/32 I think
Re: Carb O - Rings
« Reply #7 on: April 03, 2014, 08:43:28 AM »
careful with that dual outlet fuel pump. on Invaders and Intruders, the carbs sit lower tan the gas tank which can cause the fuel to siphon into the motor if the needle and seats are weak. The Kawi pump has an extra anti siphon valve built into the pump to avoid this.
58Evinrude
Re: Carb O - Rings
« Reply #8 on: April 03, 2014, 10:58:47 AM »
Would that anti syphon valve be part of a black diaphragm, that is under spring pressure? sorry, I don't have a pic of it, but it wasn't included in the rebuild kit. I'm not keeping that pump on it anyways, it was just a quick fix to get the machine running. If I can't find the right pump, I'll put a fuel shut-off on it.
Re: Carb O - Rings
« Reply #9 on: April 03, 2014, 12:48:00 PM »
Are you sure that your pump is a real Kawi pump?  The rebuild kits are LLP #07-417 and these still need to have 1 hole added the a diaphram.
58Evinrude
Re: Carb O - Rings
« Reply #10 on: April 03, 2014, 08:03:17 PM »
The pump matches what's shown on the part diagrams on Vintage Snow.. so I'd say it's a Kawi Pump. Who sells the correct re-build kit? I looked in Dennis Kirk, and didn't see one there, or on MFG Supply?
Re: Carb O - Rings
« Reply #12 on: April 04, 2014, 08:17:03 AM »
If you put the pumps side by side, you will see the Kawi pump is a bit taller than the standard Mikuni pump.
58Evinrude
Re: Carb O - Rings
« Reply #13 on: April 04, 2014, 03:28:58 PM »
http://www.ebay.com/itm/New-Vintage-Kawasaki-LTD-Fuel-Pump-Gasket-Kit-07-417-/111314870622?pt=Snowmobile_Parts_Accessories&hash=item19eae2215e#ht_145wt_1129
That's the one!! Now if I could find one in Canada, it would be great. Sorry, I can't justify spending $20 on shipping for an $8 part, especially when mailing that shouldn't be more than 3 or 4 bucks. I can buy a complete brand new pump for $35.00
Invader440
    • Curt's Snowmobiling Page
Re: Carb O - Rings
« Reply #14 on: July 04, 2014, 11:39:13 AM »
OD 9/32"
ID 5/32"
thickness 1/16"
