Author Topic: No spark...1980 4/6  (Read 17485 times)
No spark...1980 4/6
« on: April 20, 2014, 05:11:08 PM »
OK so here is what i have so far...
Last winter/spring, I had problems getting this pig started. I eventually got it going but it took lots of pulling. I went through carbs and fuel pump last fall and it started right up aterwards. I then replaced the primer and it wouldn't start (no spark)  I got mad at it and let it sit this winter, rode the Intruder instead.  I just looked it over today and here is what I found...
Swapped CDI and it had no spark. Added an aftermarket ext coil and I got spark.went back to original CDi and new coil, no spark. New CDI and old coils and no spark... One of the coils has an open when I check from plug wire to plug wire (bad coil)
Checked output from the internal coils and they seem to be within specs.
The CDI I have that works has a 3 wire connection for the coil, the old CDI only had 2 wires (dual coils)
Question: Do I need to find a CDI with the 2 wires for the coils or can I make up a set of new coils using the 3 wire setup??  Thw 2 wire CDI looks bigger than the 2 wire one. The larger CDI was on the sled when I got it, the smaller CDI is one I had laying around and neither has any visible part numbers.
Re: No spark...1980 4/6
« Reply #1 on: April 20, 2014, 05:13:06 PM »
P.S.... the wife wants to know why I am working on a snowmobile when it is all done snowing outside..... DUH!!! it is because it is not 10 below and snowing out!!! besides, I got all summer to get parts...
« Reply #2 on: April 21, 2014, 04:28:26 AM »
Is the small one the same as an Invader CDI ?
 If it is you can make it work but I believe the timing curve will be slightly diferent.
« Reply #3 on: April 21, 2014, 07:48:20 AM »
Looking through my 1980 invader/4/6 manual. I see the larger CDI is for the 4/6 motor. Guess I need to find one that works.
On the plus side, I know the internal coils are OK.... anybody got a set of external coils and a CDI for a 4/6??
« Last Edit: April 21, 2014, 08:36:48 AM by jimvw57 »
« Reply #4 on: April 21, 2014, 01:01:37 PM »
I think I've got an extra set.  I'll take a look tonight and let ya know.
« Reply #5 on: April 23, 2014, 07:58:22 PM »
Thanks!!
« Reply #6 on: April 24, 2014, 04:58:58 AM »
  I have a CDI for the 4/6 (large box)  BUT the "white wire" has been clipped.  I don't know what the white wire controls, but the box is available if you find the white wire is not a must.  Wire was clipped close to the box so you wouldn't be able to tie into it.
« Reply #7 on: April 24, 2014, 06:42:30 AM »
I believe I have parts on the way, but I'll keep it in mind. Looks like the white wire goes to the pulser coil so it is needed.
« Reply #8 on: April 24, 2014, 06:51:23 AM »
Good luck!
« Reply #9 on: June 29, 2014, 11:04:27 PM »
** UPDATE**
I got the parts installed today, sounds like I have spark. I figured out that when you disconnect the fuel pulse hose, then forget to re-attach it, the sled doesn't run too good.....Seems like now it is running on one cylinder....Left exhaust pipe started smoking (probably flooded a bit) but the right side seems like it is cold. I tried changing one of the coil wires on each cylinder but I got too tired of pulling the rope.
At least I now have spark, which is an improvement!!
** just a thought, I may have a plugged exhaust (??)  something to check out I guess..**
« Last Edit: July 01, 2014, 06:55:07 AM by jimvw57 »
