Author Topic: Oil pump leaking?  (Read 9888 times)
Johnny speed
Oil pump leaking?
« on: April 27, 2014, 12:48:10 PM »
79 Invader oil pump appears to be leaking oil at the output shaft to water pump, can it be repaired?
Re: Oil pump leaking?
« Reply #1 on: April 29, 2014, 05:15:00 PM »
Everything is repairable.  I forget if that is a shaft type seal or just an o ring.  I have attached a photo, but that one does not show exactly what I wanted to see.  I will check the garage to see if we have one fully disassembled.
« Reply #2 on: April 29, 2014, 05:28:17 PM »
I've had these leak before in the same spot.  I tried finding a replacement seal but was unable.
