Author Topic: Lift or not ?  (Read 23128 times)
BornagianKawi
Lift or not ?
« on: June 22, 2014, 07:25:18 PM »
#000073 Interceptor will be back on the snow again. With new camoplast 9796 track & 1983 Interceptor suspension. And yes with 0 miles speedo. This is a complete snow up restore. Question is lift or not? I have factory lift brackets that will raise it 2 inches. What is my gain or loss? Or would it be just cool? No pic"s at this time.
Re: Lift or not ?
« Reply #1 on: June 23, 2014, 05:44:47 AM »
  Good for you!   I suspect you will lose some top end (MPH) by lifting.  Probably not much, but this is one of a few reasons why the newer sleds aren't as fast as they could be...  in conjunction with their tall track lug profiles.  Also, you are changing the geometry of the sled so it may not handle quite as well.  Just like with most everything...  if you change one thing you may end up changing other settings.  You might try experimenting with your ski spring settings (three hole locations) for more/less ski pressure on the snow.  Love to see some pics!  Good luck!
Re: Lift or not ?
« Reply #2 on: June 23, 2014, 06:02:56 PM »
I thought the ride on our 550 was quite nice.  And while we lift all of the Intruders and Invaders, without the benefit of actually lifting an Interceptor I don't think that it is necessary.
Re: Lift or not ?
« Reply #3 on: June 24, 2014, 08:29:47 AM »
i'd run it stock....387 rides great as is
Re: Lift or not ?
« Reply #4 on: June 24, 2014, 10:50:53 AM »
Putting lift brackets on does nothing for ride quality.  The amount of travel stays the same.  The only benefit I can see is better deep snow traction.  It won't get hung up on the running boards as easily.  I'd leave them off and stay out of the deep stuff.
Re: Lift or not ?
« Reply #5 on: June 25, 2014, 06:53:52 AM »
I agree, unless I was in deep snow a lot I would leave it stock.
Re: Lift or not ?
« Reply #6 on: June 25, 2014, 11:47:12 AM »
lifting the rear will change the steering angles....when the skis are on the ground ;D
BornagianKawi
Re: Lift or not ?
« Reply #7 on: June 25, 2014, 07:59:36 PM »
I believe it will stay stock. The brackets will hang on wall for other project. 572 rides nice in stock position also. Great points , never thought of the speed one. Track and suspension will be interesting.
BornagianKawi
Re: Lift or not ?
« Reply #8 on: August 17, 2014, 05:19:11 PM »
#000073 will ride again. Can"t wait to try on snow.
Re: Lift or not ?
« Reply #9 on: August 17, 2014, 05:43:55 PM »
  If we get as much snow as we've had rain this summer...  there won't be a problem with that.  You might end up having to take out a small loan to pay for all the gas you burn!  Rumor has it we will be getting snow in Oct this year -
Re: Lift or not ?
« Reply #10 on: August 17, 2014, 05:46:25 PM »
  Oh, forgot to mention - sled looks fantastic!
Dandb7
Re: Lift or not ?
« Reply #11 on: August 18, 2014, 07:16:23 AM »
I agree, the sled looks in real good shape..!
Bring on the snow..... :)
1979 Kawasaki Drifter 440
1989 Arctic Cat Pantera 440
