Author Topic: removing rear wheels  (Read 11807 times)
bryan_damone
« on: October 30, 2014, 07:10:37 PM »
I'm disassembling my rear skid to fix cracked brackets. Can anyone enlighten me as to a good way to remove the rear wheels from their axle? Mine do not want to slide off the shaft.  Thanks. 1978 invader.
Re: removing rear wheels
« Reply #1 on: October 30, 2014, 07:23:41 PM »
sometimes the aluminum oxidizes a bit.  They wheels are only held on by plastic sleeves, so there is not very much to hold them in place.  What I have done is supported the wheel in a vice very close with the vice jaws tight in to the shaft and then drive the shaft out.
« Reply #2 on: October 31, 2014, 07:15:28 AM »
Clean up the shaft and lube it before you start driving it out.  Use a rubber hammer if you have one.
bryan_damone
« Reply #3 on: November 01, 2014, 08:52:22 PM »
Thanks gentlemen.  After getting one wheel off, I was able to drive the shaft out.
bryan_damone
« Reply #4 on: November 10, 2014, 01:04:17 PM »
We have a seized cross shaft! Yipee. The short 8 inch one (39116-3501).
bryan_damone
« Reply #5 on: November 11, 2014, 07:39:25 AM »
Well I have tried all the non-destructive approaches. No luck. I am drilling out most of it put and will remove the last little bit with a muriatic acid bath.
bryan_damone
« Reply #6 on: November 18, 2014, 02:24:12 PM »
After drilling a 1/2 inch hole all the way through the aluminum shaft, submerging the remainder in 1L of muriatic acid for a couple hours dissolved the remainder. Does anyone have an extra shaft 39116-3501 they could part with? Thanks.
